-   -   rust repairs - sit down before you read this....! (http://forums.pelicanparts.com/porsche-911-technical-forum/426404-rust-repairs-sit-down-before-you-read.html)
RG5 08-22-2008 04:57 AM
***FINAL STAGES*** rust repairs - sit down before you read this....!
My beloved Carrera is in for some restoration work to cut out some rust that has been lurking in there for some *unspecified* period of time.
There are two know problem areas, the RHS inner wall under the fender and the sills.
This is what we found when we removed the fender and scraped away a bit.
http://forums.pelicanparts.com/uploa...1219405368.jpg
A bit of angle grinding and fabrication and welding, we now have this:
http://forums.pelicanparts.com/uploa...1219405431.jpg
Today the mechanic started on the RHS sills. You know there is a problem when he calls on the mobile after you know he has started. "You better come back, the rust is more than I expected". We all know the rust you can see is only the tip of the iceberg.
So, after seeing this:
http://forums.pelicanparts.com/uploa...1219405563.jpg
and this:
http://forums.pelicanparts.com/uploa...1219405626.jpg
After the mechanic started grinding out the problem areas, we are now faced with this:
La-la-la-oooh!
http://forums.pelicanparts.com/uploa...1219405771.jpg
http://forums.pelicanparts.com/uploa...1219405834.jpg
http://forums.pelicanparts.com/uploa...1219405911.jpg
http://forums.pelicanparts.com/uploa...1219405962.jpg
In the words of Magnus Magnusson , "I've started so I'll finish" all we can do here is ride out the wave, cut it all out and weld in new metal and hopefully at the end of this journey I will have a pretty much sorted Euro Carrera that will be good for years to come.
Pretty much in every other aspect this is a great car mechanically and cosmetically,
There is something slightly alarming seeing your pride and joy cut to pieces, but I think what could be the situation 3 or 4 years down the track I'm really glad I am doing this now.
Will post some updated pics soon.
if anyone wants to dial out some free sympathy, I'm sure my 911 would appreciate it.
RG5.
VroomGrrl 08-22-2008 05:03 AM
Poor car! Went in to have a couple of cavities filled and ended up getting a bunch of root canals! Hope it all turns out well, and is not TOOOooo costly!
Kevin Taylor 08-22-2008 05:43 AM
Rust never sleeps!
K.T.
1973 911 E 2.4 MFI
1983 911 SC
1978 911 SC
1965 Devin "D" / 1967 912 Power Plant
1998 GMC Serra 4X4 Z71
John Deere LT166
Money Can Buy Happiness........Buy A Porsche......a
Paulporsche 08-22-2008 05:48 AM
Where are you located? Where is the car from?
Rot 911 08-22-2008 05:54 AM
You should try owning an MGB, I cut out and welded in more inner and outer sills and doglegs than I can remember. I could probably do them in my sleep.
RG5 08-22-2008 06:00 AM
I am located in Australia, the car is a UK Carrera but was imported in the late 90s.
DaddyGlenn 08-22-2008 06:02 AM
I have a few rust bubbles that I am trying to stay in denial about. This is the kind of stuff that keeps me awake at night. :rolleyes:
Ron.G 08-22-2008 06:07 AM
Been there before. It's ugly but it really is not that bad of a job.
I bet if most people popped there fenders off they would see the same thing.
Good luck with the project. How did your front bumper supports look?
RG5 08-22-2008 06:22 AM
yeap - few rust bubbles and that is the starting point. This was picked up by my mechanic who gave a thorough look over the car when he first had it in for a service. Its when you start poking around you see the demons behind the surface. Mine is a long term view on the car so I would rather take the plunge now rather than later when the job is a lot more severe.
Bumper supports look OK. When you grind all the rust out, it looks bad at first but all is involved is a bit of skill with galvanized repair metal plate and a welder. Then it can all be put back together and refinished.
Still, you would want to be sitting down when you get the invoice. I think I will take my own chair just to be sure...
gestalt1 08-22-2008 08:41 AM
wow, i've heard that galvanizing has a limited life span but not sure i've seen rust that bad on an even an early car before. the nice thing about rust (?) is that you can get into those closed off areas and rust proof them and also the replacement metal is all new and sound when done. good luck!
jh225 08-22-2008 08:42 AM
What year is the car?
JP911 08-22-2008 08:47 AM
Look at the bright side, at least it didn't make it to the rear torsion bar tube. If that had happened, the engine and trans would be out and the car on a suspension jig.
Macroni 08-22-2008 09:56 AM
Is this a 70s car?
old man neri 08-22-2008 10:04 AM
I do believe that is a 3.2 Carerra.
emac 08-22-2008 10:20 AM
I don't care what anyone says about driving her all year long. That is why I have a garage queen!
Wayne 962 08-22-2008 10:24 AM
That much rust on a 3.2 Carrera is odd. I'm guessing that it's a 1974-75 Euro Carrera or a Carrera 3.0 from 1976-77? Hard to tell from the photos...
-Wayne
wolf 08-22-2008 10:24 AM
Can all this be deleted please?http://forums.pelicanparts.com/suppo...eys/loki16.gif
Jagshund 08-22-2008 10:39 AM
A little sympathy
I can say with some degree of certainty that I know how you feel . . .
http://forums.pelicanparts.com/uploa...1219426724.jpg
And all I wanted to do was fix a rust bubble . . .
burgermeister 08-22-2008 10:45 AM
Ouch! Not much else to say.
I thought I had quite a bit of rust in my LH rear fender-to-rocker area ... but it was clean by comparison.
The holy part was surprisingly thin ...
http://forums.pelicanparts.com/uploa...1219426934.jpg
luckily, the area behind the fender was just surface rust.
http://forums.pelicanparts.com/uploa...1219426959.jpg
Shade Tree fabrication of a decreasing radius bend using sophisticated metalforming equipment:
http://forums.pelicanparts.com/uploa...1219427058.jpg
"Good as New"
http://forums.pelicanparts.com/uploa...1219427083.jpg
rnln 08-22-2008 01:36 PM
I feel like some invisible bugs is crawling on my skin.
