polizei's Avatar
How to clean 3.2 throttle body
Does anyone have a recommendation on how to clean a 3.2 throttle body? Thanks guys.
Andy - 1987 911 Carrera Coupe
Old 08-22-2008, 05:54 AM
Friend of Warren
I assume you are removing it. If so, get some spray brake cleaner, take it outside and spray the inside and outside liberally. The brake cleaner will not leave any residue and dries fast.
Kurt V
Old 08-22-2008, 05:57 AM
After you see how much gunk is in your throttle body you wonder how much is in the intake runners.
Cue the slippery slope
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 08-22-2008, 07:19 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Answer: A LOT more. If the oil tank has ever been overfilled (100% probability) then that oil gets spit into the intake via the oil tank vent hose that goes into the rubber elbow atop the throttle body.
Agreed that it should be removed to clean. It's not too hard to remove and you can reinstall w/out replacing the large sealing o-ring if it's still pliable and soft. If the o-ring is hard, it may not re-seal well and you'll have an air leak w/ a lean running condition. Should be able to source the o-ring at a local hardware store if you need one in a pinch. If not, Pelican should of course have one.
Kevin L
'86 Carrera "Larry"
Old 08-22-2008, 07:33 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
To cure this..I disconnected it and put a filter at it's end.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 08-22-2008, 09:24 AM
polizei's Avatar
Is there any amount of cleaning that can be done to the inside of the manifold while it's still bolted to the motor and the throttle body is off? MAN! I should have cleaned the manifold while it was completely disassembled!
Old 08-22-2008, 09:26 AM
Counterclockwise?
Why not use throttle body cleaner?
The stuff is actually intended to be used while the car is running. I wouldn't use it while running my Porsche, but I have used this technique on lesser cars.
Rod
1986 Carrera
2001 996TT
Old 08-22-2008, 09:42 AM
KTL KTL is offline
Schleprock
KTL's Avatar
So did I. I put a baffled oil catch can on the hose. It seems to catch more condensation than oil!
The only thing i'd use to clean the intake installed is that Seafoam stuff that you feed the engine from the intake while running. Never used it myself though. You can swab out the inside of the intake with a long screwdriver and a bundle of paper towels attached to it. But it won't get everything out from the six intake runners you can't reach.
It's really not a big deal. There's thousands of 3.2's running around with oil film sitting in the intake.
Kevin L
'86 Carrera "Larry"
I recently had my intake out for easier access to the front of the engine and noticed the throttle body was caked with gunk. I took it off the manifold and sprayed it with Seafoam which got the soft stuff off but I had to use brake cleaner to get the baked on carbon off especially around the butterfly. I did replace the o-ring. After I put everything back together I did notice better throttle response but I also replace cap, rotor and wires at the same time.
If you use Seafoam you have to let it soak for quite awhile.
1955 VW oval window ragtop
1971 & 1974Triumph Bonneville
1985 Porsche Carrera
2013 Toyota Tacoma TRD
2016 Triumph Speed Triple R
Old 08-22-2008, 10:21 AM
