Jinglling noise from rear right wheel I think
Hi Folks,
I have recently noticed a "Jingling" noise as I'm driving along as low speeds (under 40Km/hr). It sounds like 2 metal keys jingling on a key ring. I have searched all over the car but can’t find anything loose. I think its coming from the rear right (driver's side) wheel. I suspect that it is coming from the unsprung portion because it is even present when the road is relatively smooth. ....... I can’t find anything loose though. I would not describe the sound as "rubbing" or "clicking". Any thoughts on what might be the culprit??
Thanks!
Old 08-20-2008, 03:12 PM
kilodawg's Avatar
You don't say what kind of wheels but the older center caps with the prongs used on fuchs can be loose and cause a similar jiggling sound.....
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 08-20-2008, 03:20 PM
joe payne's Avatar
Make sure it's not your chain tensioners making that sound.
jtp911
Old 08-20-2008, 06:08 PM
I was going to say centre caps as well. 2 of mine make that same noise and had me worried that it was tensioners.
Old 08-20-2008, 06:38 PM
had the same noise. It ended up being the upper cover of the shock(bilstein) jingling against the shock body. There were telltale wear marks on the shock body. I wondered for the life of me how a tire could rub on that portion of the shock. Of course it couldnt have.... it was the cover(the piston cover) banging on it. Strategically placed sticky foam tape remedied the problemo.
'82 911
previous:
'86 951
'72 914
Old 08-20-2008, 06:47 PM
wente's Avatar
mine did that - it was the parking brake. the shoes had disintegrated and there were small chunks floating around. The spring that holds the shoe was scraping against the drum. And, slightly pulling the e-brake while rolling would change the sound.
Ellsworth Wente
87' 911 Targa
09' Cayman S
48' Lincoln Continental
Old 08-20-2008, 07:57 PM
slodave's Avatar
Have you seen your cat lately? Neighbor missing theirs?
Old 08-20-2008, 11:17 PM
I eventually found the noise. Luckily, it wasn't the neighbour's cat! It was the Porsche badges on the centre cap of my front wheels. Thanks for the advise.
Old 08-24-2008, 02:49 PM
