-   -   Not Another Torque Wrench Thread! (http://forums.pelicanparts.com/porsche-911-technical-forum/426806-not-another-torque-wrench-thread.html)
therotman 08-24-2008 01:49 PM
Mine is different though......I know it will be snap-on.
It will be my first one, and have no idea what type and size should be the first. so what model should I get?
Their web page is here
RWebb 08-24-2008 02:06 PM
1/2 for tires
3/8 for nearly everything else
Por_sha911 08-24-2008 02:09 PM
Read here.
The search button is your friend.
billybek 08-24-2008 02:13 PM
Originally Posted by RWebb (Post 4137850)
1/2 for tires
+1...
Keep in mind the values that you want to measure. The mid range for the torque wrench should be around that value.
therotman 08-24-2008 02:34 PM
I've searched threads, but it sounded like the one through PP was the best deal.
Snap-on is free, so sorry wayne, only 3 orders this month.....
I guess here is my real question
#1
or #2
billybek 08-24-2008 02:52 PM
I would go with #2. You will regret not having ratcheting action with the fixed wrench #1.
Consider this as well, many of the torque ratings that you will find on a Porsche are lower than the 20 ft/lbs that is the bottom end of your second selection. My Snap-On has a bottom end of 5 ft/lbs and a top end of 75.
It is a flex head, but couldn't find my glasses to read the model #.
Now, let the rest of us know how you get Snap On stuff for free!!;)
EarlyPorsche 08-24-2008 03:43 PM
Is it ok to get a 3/8 and then adapters to make it 1/4 or 1/2?
imcarthur 08-24-2008 03:53 PM
I've snapped several adapters. 1/2" 50-250 is the single best bet imho. Get a good one but never, ever use it to undo things. Not even once! That's what breaker bars are for. I just bought my 2nd so I learned the hard way.
Ian
RWebb 08-24-2008 05:20 PM
sure but it -of course - does not change the fundamental accuracy of , nor the range of, the wrench.
it would be very cumbersome to use a 3/8 + extender to do the wheels
1/4 is just not needed for 99.5% of owners.
rnln 08-24-2008 05:43 PM
+1 but wheels lug/nut instead of tires :)
1/2 for tires
therotman 08-24-2008 07:36 PM
Is #3 , with 5-75 lbs, a better option for my porsche then?
It doesn't seem as important to me to get the 15 lbs bolts at the perfect torque- am I wrong about that?
I can use my credit card reward points for Snap-on gift cards :)
billybek 08-24-2008 08:49 PM
I would say that it is important, but I have a biased opinion on this matter!!;)
edit:
Having a top end of 75 ft/lbs probably means you will need two torque wrenches as mentioned before. 1/2" and 3/8" drive...
If you have both, you have most of the range covered.
