-   -   odometer reading low (http://forums.pelicanparts.com/porsche-911-technical-forum/427217-odometer-reading-low.html)
amschnellsten 08-26-2008 06:59 PM
I noticed today that my odometer is reading low. I can drive roughly 10 miles before my odometer reads a mile. My speedo is fine, what could be the culprit and what should I check first? oh yeah, My car is an 84 3.2.
dentist90 08-26-2008 07:02 PM
Speedo works OK? Possibly busted plastic gears inside, but on the other hand... great for resale!
amschnellsten 08-27-2008 04:46 AM
speedo works fine, well it reads a little off compared to gps but nothing substantial.
TubbyAZ 12-02-2010 05:51 PM
I just noticed this as well on my 85 Targa.
My speedometer needle "sticks" when pulling away from stopped. As I get to 20 or 30 mph, the needle jumps up to the true speed, at least the local radar speed signs tell me it's relatively accurate.
After this started happening, I noticed a tap on the glass would free the needle sooner. It was during one of these taps that... I... hit... the tripmeter reset. So I am guessing I have two issues and need to send it away.
I've seen an outfit in LA mentioned a lot, Hollywood something? They still the place to go to fix and adjust?
And will I damage anything if I drive it without a speedo in it?
Thanks in advance
OSI930 12-02-2010 09:06 PM
North Hollywood Speedometer. Just got my speedometer back from them. The odometer quit working and I had them adjust and calibrate the speedometer as well. Works perfect now and they turned it around very quickly.
dshepp806 12-03-2010 08:15 AM
Yeap,..NHS is the one!
Best,
Doyle
