Did my heater back-date this morning. This was the final touch on my rebuild. At this point I am VERY tired of working on the car - only put 250 miles on it so far and it is time to enjoy it.
Ok, so here is the deal. I had to rotate the wire that connects to the pressure sender in order to install the new fan housing outlet on the right side of the engine. When tightening down the 6mm nut it broke the "pole" on the sender (when I say "pole" I am referring to the threaded piece that the 6mm nut screws onto). This pole seems to be brass (maybe?) and has a wire inside of it - it basically cracked in half and I can see the wire inside. I was able to get a new nut on what was left of the pole, but my pressure gauge is now pegged at the top. Is there a fix for this or do I need to buy a new sender? Luckily it isn't an expensive part, but it is a big pain to install. Please tell me someone has done this before.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Here is a pic for reference. Not sure what that black casing is - mine doesn't have it.
looks like a new one is in your future.
So there is no fix?
Why would it make a difference that the top half of the pole broke off? Is there something at the tip that affects how it works? Is that top part (black portion) removable? I have another sender on my old engine.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) Last edited by mca; 09-20-2008 at 04:49 PM.. |
somehow you have an open circuit. that's why the gauge is pegged. if you can jerry rig it to function with glue or something, fine, but they aren't that expensive.
ditto!
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
make it right...
Doyle
Bump ....
Still looking for answers as to why the tip is so important to the proper function of the sender. What makes the circuit close? "make it right" ... well, sometimes you have to improvise on these cars. I hardly think my car would be "wrong" if I found a way to fix it.
Tim 82 SC 90 C2 Yasowatt |
Less brakes, more gas!
Yiup.. new one. I over cranked mine and the threaded shaft broke in half. There is a copper wire soldered to the top of the shaft so when the shaft separates the wire does not make a good connection, apparently.
I had to order a new one to replace the brand new one I broke... oh of course, later, going through a random box looking for some other new part I bought I found a second new replacement I had bought and forgot I had... *sigh* I guess forgetting you already bought two is what happens when you take 3 years to rebuild a motor or am I just gettin' old....Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
No, you're car wouldn't be wrong if you "rigged" it (no one said it would be....). It would be just that: rigged. I wouldn't toy with something as critical as oil pressure intrumentation......thru any process but the proper one: a new one (as many have suggested, already) Do let us know of any clever rigging that functions well for you. Doyle
Thanks for the replies.
If I fix it I will let you all know. Maybe it will be as simple as soldering the top of the post (what is left of it).
