Nothing like a 911
FrankieG's Avatar
Low Idle and Stall when Warm
Recently, my 82 911SC has experienced a odd issue. The car can be standing unused for weeks, and it starts up right away. Never has a problem on cold starts, except for some white smoke occasionally. The problem is that after driving the car, and then shutting off the engine, on restarts (after sitting for a little while), i have trouble keeping it running, the idle drops and unless I keep giving it gas, it just dies. However, once I start driving again, after a minute or two, it runs fine. Any thoughts? Thanks
1982 911SC Targa
2009 Cayenne
If it doesn't kill you...it makes you stronger
Old 08-27-2008, 06:09 AM
Fast Corners's Avatar
A bad fuel accumulator causes poor hot start characteristics.
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 08-27-2008, 06:52 AM
Nothing like a 911
FrankieG's Avatar
Thanks - is that a major repair?
1982 911SC Targa
2009 Cayenne
Old 08-27-2008, 06:57 AM
Somatic Negative Optimist
Gunter's Avatar
Without knowing more about the general condition or maintenance of the engine, it's all just guessing.
Hot start issues:
Check valve on the fuel pump.
Accumulator.
Fuel filter.
Vacuum leak.
And a few dozen more......................
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-27-2008, 07:38 AM
It could be a gummed up fuel distributor due to "old fuel" in the system - lack of use.
I would replace the gas in the tank with fresh 93+ oct, add concentrated Techron and take the car for a long/spirited drive with lots of WOT. That might flush the "bad stuff".
Old 08-27-2008, 07:40 AM
Gunter is correct in that there are other things to check but, judging from your description of the starting/running behavior for a hot motor I would bet on the accumulator. A gummed up fuel system, clogged filter(s) vacuum leaks, etc. would have a tendancy to affect the performance either when the car is cold or hot.
A fuel accumulator is not a major repair. A few wrenches, some busted knuckles and your done. It is the olive drab cannister thing on the back left side of the engine compartment.
FC
'73 911 Track Car
'93 968 Wife's Car
Old 08-27-2008, 10:08 AM
Nothing like a 911
FrankieG's Avatar
Thanks so much for the responses, at least I now have a starting point. I'll check out the accumulator.
1982 911SC Targa
2009 Cayenne
Old 08-27-2008, 10:10 AM
