disfrutalaruta
HELP a newbie get a new project on the road! Fuel?
Hello,
I am a proud new owner - 1977 s with a 3.0 from a 1979 sc. Its a beater - but its mine!
I have almost no history for the car and I can only assume it hasn't been running for a while. Here is my problem that I hope you all can help me with:
The car had a fuel line leak - I turned the key on and fuel went everywhere. Fixed the leak.
The car now starts and idles ok but dies after a while and doesn't really have much throttle response. It will rev up a bit but not much. Once it gets hot - it dies and/or putters along.
I have read that I should not hear the fuel pump until I start the car. When I turn the key on (before starting) I hear a loud whirring. This stays on when the car is running and the noise changes pitch as the idle goes up and down.
Like I said - its a beater but I think if I fix what seems to be a fuel problem, I could at least take it for a spin.
Potentials:
Fuel Pump - the mechanic that did the PPI said the fuel pump was bad. But when I turned on the key before I fixed that hose fuel went everywhere and the car does start and idle ...
Filter?
Accumulator?
Relay?
Any help you folks can offer would be great!
Thanks,
Shane
Shane
77 911s w/ 3.0L
Architect, Surfer, but mostly a Dad
Old 08-10-2016, 08:01 PM
Basic CIS troubleshooting...........
Shane,
You need to use a pressure gauge to determine your fuel pressures (control, system, and residual). This is a mandatory tool for any injection system troubleshooting. If you don't use it, you will be leaving too many critical variables in the equation. And you are wasting a lot of your valuable time.
Tony
Old 08-10-2016, 09:00 PM
Member 911 Anonymous
DRACO A5OG's Avatar
^^^ very good advice
The pump is warning you that it will die soon, the armature is stuck.
You can have it re-built. While you are there, I suggest a new filter.
'85 Carrera Targa
PCA/POC
Old 08-10-2016, 09:01 PM
As above it is imperative to test fuel pressures to determine component issues. My '79 was sitting for eight years. I flushed lines, replaced tank, fuel filter and tested then cleaned injectors. Then did all the pressure testing per cis manual. Found a clogged screen in the wur causing lean conditions. Took apart, cleaned screen , adjusted pin with pressure gauges attached and now have a great starti g and running machine. A pleasure to drive. I read all these posts, listen and do the pressure tests and you too shall be driving your ratty German go cart.
Old 08-10-2016, 09:13 PM
disfrutalaruta
Thanks for the advice guys. I think the pressure tests might be out of my range at this point. The FP and the filter are getting replaced this weekend and we will see where i stand after that. If that doesn't make things right its off to the mechanic. Anyone know a good one in Austin?
Shane
77 911s w/ 3.0L
Old 08-12-2016, 03:48 PM
Under the radar
Trackrash's Avatar
How old are your fuel hoses? You probably should think of replacing them, considering todays fuels. The last thing you want is a fire.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-12-2016, 04:57 PM
