CRNT918's Avatar
Question '87 Fuel Line replacement
I need to replace the engine fuel line on the '87 cab, the one that goes from the filter to the fuel rails. I've got it loose, but can't get it out. From what I can see,
I'll have to take off the intake manifold, and/or drop the engine out of the car. Anybody have any tricks up their sleeves?
Thanx,
Pete
PCA-Chicago Region-DE Tech Coordinator-Retired
PCA-Chicago Region GingerMan DE Co-Chair-Retired
1987 Cab-under construction-Sold pending pickup
1986 911- Race/DE car-Sold
Old 11-08-2008, 04:23 PM
krd krd is offline
krd's Avatar
i just did this, remove passenger side intake and snake it out. do yourself a favor and replace it with braided fuel line and AN fittings.
1988 porsche 911 "CE" cabriolet
Old 11-08-2008, 04:45 PM
mnmasotto's Avatar
Fuel Line
I just replaced both fuel lines. I did not remove the intake manifolds. I removed the accessory heater motor and airbox. The airbox does not need to be removed if you are not replacing the rear fuel line. The solid brass part of the fuel line you are talking about is the hardest part to take out. I simple cut my fuel lines off. This saves alot of work. I replaced both fuel lines in less than two hours.
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 11-08-2008, 05:34 PM
krd krd is offline
krd's Avatar
oh forgot to tell you that too, cut them out
Old 11-08-2008, 05:37 PM
Throw it on the ground!
Thanx,
Pete
Pete, since I've got an 87 engine on a stand here are a couple of pic showing the hard line attachment points(3). One 10mm hex bolt in front (alt side), one 4MM hex cap bolt in rear center and one more 10mm hex bolt in the rear. I would think this would be quite difficult to remove with the engine in but I'm sure it can be done. Hope the pics help.
Front view - shows PO's repair of leak
Rear view of 4mm hex cap bolt
Side view of 4mm hex cap bolt
Rear view of 10mm hex bolt
Side view of rear 10mm hex bolt
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 11-08-2008, 05:46 PM
CRNT918's Avatar
Getting it loose was no problem, cutting it out would be no problem either. I figured if I could get it out in one piece, I could get the new one back in.
Old 11-08-2008, 09:00 PM
mnmasotto's Avatar
Lines
Trying to remove that long fuel line in one piece is going to be difficult. I tried to remove mine without cutting but finally gave up. The stiff brass portion makes it difficult.
2007 997 GT3 - SOLD
Old 11-08-2008, 09:05 PM
CRNT918's Avatar
Hopefully the pics will help devise a plan.
Old 11-08-2008, 09:20 PM
CRNT918's Avatar
Thanx to everyone for the pix and the advice, after breakfast I'm going back out to give it another whirl.
Pete
Old 11-09-2008, 05:10 AM
CRNT918's Avatar
Got it in, pix and story tonight!
Old 11-10-2008, 03:01 AM
