Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
What is this warning light?
I have a 69 911 with stock gauges. On my main tach, the red light obviously goes off when the engine gets up to speed. The top yellow light only *sometimes* shuts off though...often it's on as I'm driving.
I know my fluids (Oil and tranny) are fine...what does this gauge do? Is it brake related?
It's the top light in this image:
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 09-01-2008, 10:08 PM
Rennch on YouTube
rennch's Avatar
Oh, and before you freak out, the car was off when this was taken. My oil pressure isn't that bad.
Michael O'Neal -
Old 09-01-2008, 10:09 PM
Pkaaso's Avatar
That's the "Change Engine" light...
If you aint breakin' it, you aint racing it hard enough!
1974 911 3.0 Euro Sahara Beige/Black
Old 09-01-2008, 10:43 PM
Rennch on YouTube
rennch's Avatar
Cool...I'll throw that 3.6 in then. Thanks!
Michael O'Neal -
Old 09-01-2008, 10:46 PM
Formerly reformed
Parking brake?
1968 911P (Paperweight)
Old 09-01-2008, 10:47 PM
Rennch on YouTube
rennch's Avatar
Well, that's when it shuts off. I need to find the switch or something...what makes it turn on and off? Is it directly connected to the eBrake handle?
Michael O'Neal -
Old 09-01-2008, 10:50 PM
There's a switch at the rear of the parking brake handle. Pull up the carpet to expose the brake handle, remove the bolts that hold down the handle to get to the switch.
Old 09-02-2008, 04:24 AM
You may only need to adujst the switch so you can save some effort. On the passenger side of the brake handle, near the base, you can see a screw--that adjusts the position of the switch. Release the brake completely, them pull it up one "click". Loosen the screw and slide the switch up or dow until it just lights the warning light on the dash (don't forget to turn on the ignition.). Tighten the screw and you're done.
BTW, the dash light is also wired to the master cylinder warning lights, at least on some later cars--not sure about the 69. You may want to investigate there if the E-brake switch adjustment doesn't solve your problem.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-02-2008, 06:14 AM
Rennch on YouTube
rennch's Avatar
Ok, thanks all...
Question...what does the master cylinder warning light indicate? Low brake pressure?
Michael O'Neal -
Old 09-02-2008, 08:15 AM
911Etarga's Avatar
The top light will blink if you have a Master Cylinder problem. It will stay solid if your E-brake is on. Are your brakes mushy?
'71 911E Targa
Old 09-02-2008, 09:52 AM
911Etarga's Avatar
I believe it blinks because of low pressure in your master cylinder.
'71 911E Targa
Old 09-02-2008, 09:53 AM
Rennch on YouTube
rennch's Avatar
The light is staying on solid. I'm going to try and adjust the sensor first, and if that doesn't work, go from there...
Michael O'Neal -
Old 09-02-2008, 10:04 AM
There is a pressure switch on the master cyl.It's under a rubber boot.Try pushing the "button" in and see if the light goes off
Old 09-02-2008, 10:10 AM
<insert witty title here>
Christien's Avatar
Are you sure? Mine's the opposite - it blinks when the parking brake is on. My parking brake is all out of adjustment and I couldn't get it to stop blinking, so I just disconnected the lightbulb. And my brakes are fine - 2 year old master cylinder and tons of pressure (as was evidenced by some ********* in traffic in front of me last week, causing me to lock up all 4 wheels to avoid an accident).
I always assumed that a solid light was a warning for low oil pressure, hence the label "oel".
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 09-02-2008, 11:08 AM
911Etarga's Avatar
The bottom one on mine is the oil pressure light. It's a '71...might be different. The oil light in my car comes on when I start it and it is idling. When I rev it up the light goes off. Does this sound familiar?
'71 911E Targa
Old 09-02-2008, 11:21 AM
Christien's Avatar
Really? Never seen that before. Not that I'm an expert, by any means, but all the early cars I've ever seen have been oil on top, alternator on the bottom. In any event, the pic posted above says oil.
Old 09-02-2008, 11:23 AM
911Etarga's Avatar
Maybe my wires/bulbs are in the wrong holes?
'71 911E Targa
Old 09-02-2008, 11:30 AM
Christien's Avatar
Could be - if you've ever had your gauges out you know how easy it is to mix them up! Whenever I pull a bulb I always make sure to wrap a piece of tape around it and label it, even if it's something like "9:00" or "far left". What does your gauge face say? There should be a little G symbol for generator, or alternator.
Old 09-02-2008, 11:32 AM
911Etarga's Avatar
It looks the same as emptyo's.....
'71 911E Targa
Old 09-02-2008, 11:47 AM
Rennch on YouTube
rennch's Avatar
I don't know if that's the oil light...I've heard it's the brake light definitively. But, there are plenty smarter than I. Is it possible it's an oil light? If so, what is it connecting to?
Michael O'Neal -
Old 09-02-2008, 12:05 PM
