Question: What are these brakes?
Im planning a brakeupgrade and these calipers were offered to me:
Any guesses? ![]() ![]() ![]() ![]() The should be 996tt rear calipers, but when compered these pictures to the ones on ebay, there was some small differences:
911-87 mit der 3.6 V-Ram und alles spaß Last edited by Bill Verburg; 10-07-2008 at 03:53 PM.. |
Insert Tag Line HERE.....
paging Bill V.
They had only a Brembo part.no. No porsche number att all. Could it be, that they are some brembo upgrade brakes or similar???
911-87 mit der 3.6 V-Ram und alles spaß |
They are not 996tt rears, have you got some better pics from the top/outside view
Send me the Brembo part numbers and I may be able to tell what they are.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I will be able to check the caliber on weekend. And if they seem fine, so i will buy them. Then i will take the number for you to check. /J
I'd want to know exactly what they were, and if they were indeed an "upgrade" before I purchased them. Can you ID them before the weekend?
No, i cant ID them before... They have been already in a 911, and the adapters are also included. And im 99,9% sure, that they are an upgrade to stock brakes...
If those are the rears what are you planning to run up front and with what rotors? What are they going on anyway?? You don't mention what car you have.
Tony G 2000 Boxster S |
And i was planning to run them with my original rotors.... lets see how it works.
Not that I'm an expert, but anytime you use a caliper that has more clamping power and a bigger pad area creating friction on a surface area designed for a smaller pad (ie: your stock rotor), the result is higher heat (from friction) generated and NOT being able to dissipate properly. That results is brake fade, possible boiling of fluid, premature failure of the rotor when the rotor is being used during 'exercise' at the track. If you are looking for the bling factor, spend away. A proper upgrade involves bigger rotors (or thicker rotors) to properly handle the increased clamping power of the caliper and bigger pad.
I don't think those rears will give you any "upgrade" if you plan to use them on the front. Search Bill Verburg's name for upgrade threads and visit his webpage that gives you info on rotor sizing.
I'm not pro at these things either, but i still beleive that the desing in nearly 20 years newer calibers can easily outrun the old ones. Buuuut we´ll see ![]() I got some new information from the seller... they were originally black with white Porsche text on the side. And they are ment for max. 28mm rotors. I hope that i can get brembo code also soon...
911-87 mit der 3.6 V-Ram und alles spaß Last edited by Jaskas; 10-08-2008 at 10:25 AM.. |
If you look at the pads, they look like 996 pads, possibly rear
here is what full set of 996tt calipers looks like, maybe you can tell if they are the same as what you are looking at
![]() the fronts are 36/44 and want a 330x34mm rotor, the rears are 28/30 and want a 330x28mm rotor. Neither should be used on stock rotors because they are too small in both radius and thickness. If you want to upgrade Carrera brakes start with the smallest rotors that don't get too hot in the way you use the car. putting big calipers on small rotors does nothing positive for you. the following is copied from a previous post The heart of any BBK is the rotors 284x24 is just too small for quick 3000# car. so up grades come in the following steps step1(fine for 90% of all users) 964 298x28 w/ Carrera rear 299x24, calipers would be 964 f/r or 996 f/r 996 318x28 w/ Carrera 299x24, calipers would be 964 f/r or 996 f/r Step2(fine for 99.99% of all users) 930 304x32 or 993 304x32 f w 930 r 309x28, calipers would be 930f/r, 917f/r, 993 f/r, 993f/965r Step 3(overkill for almost any car) 993tt 322x32f/322x28r, calipers would be 993tt f/r 996tt 330x34f/322x28r, calipers would be 996tt
Thanks Bill! Great advices!
But i'm still so stubbern, that i want to bang my head to the wall myself first. And then i will come to the same conclusion than you ![]() But then i have the 996 rears ready for the step 1 upgrade ![]() Quote:
-38 -95 -5L24 -X93 35 pads are Ferodo DS2500 (FCP1308H 127) which means for the pads are for: - Carrera 2, 4, cabrio 09/97-> 911 3.4 3.4 Carrera 24V 1998-> 997 3.6 3.6 Carrera 4 All 06-> 997 3.6 3.6 Carrera All 06-> Boxster (986) 2.5 2.5 24V S Boxster (986) 2.5 2.5 24V
