Hi
Hello Everyone,
![]() I have an 84 Carrera and I want to cap off the brake line while I do some maintenance, can any one tell me what size fittings I need? Thank you.
Home of the Whopper
What are you trying to do? If you just want to remove a caliper, keep the brake pedal depressed and the reservoir or MC will not drain. Then just bleed the brakes and you will be good to go.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
+1 on the MC. Just hold it down with a stick about 1". You can get some plastic caps if you must. Or tape if you're grinding nearby. Just rinse with brake parts cleaner before reass'y.
Hi
Thank you, Gentlemen.
