Moke81's Avatar
Symptons of possible broken head studs
Just started to make a strange noise under a load, almost sounds like a air leak but goes away with higher rpm's. I had a valve adjust done back in March and the wrench found a broken head stud in the valve cover. He said it would be ok for awhile because it was one in the middle but with one breaking there will be more to follow.
Could this be one of the symptons? and what other things will the motor do?
_______________
1981SC Coupe
Barclay
Old 09-04-2008, 12:42 PM
Bill Verburg's Avatar
Please, Just take it to a competent mechanic and have it fixed
Bill Verburg
Old 09-04-2008, 01:31 PM
CMDR Perry's Avatar
Broken head studs
The cylinder with a broken head stud can sound like it has an exhaust leak at the header flange when idling but it is actually the power stroke expansion gas coming out of the head gasket or base seal. I have this problem right now, top end rebuild coming this winter.
Old 09-04-2008, 01:58 PM
DanielDudley's Avatar
I don't know about 911s, but I have seen that kind of leak destroy heads on 914s. Think red hot flames on aluminum.
Old 09-04-2008, 02:09 PM
19 years and 17k posts...
azasadny's Avatar
Sounds like a broken head stud(s) to me. That's what mine sounded like...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 09-04-2008, 02:41 PM
Vin-barrett's Avatar
sometimes you can drive with the broken stud if it hasnt started to leak yet but it seems too late in your case.
the diesel sounding exhaust leak is ruining your cylinder and head mating surfaces.
Ask how I know....
Unfortunately it sounds like yours needs to be fixed now. I wouldn't drive it anymore in hopes you can salvage the head and/or cylinder with the broken stud.
-Vinny
1983 911SC
Old 09-04-2008, 05:24 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
im no expert but in the past, ive searched this topic and i recall reading that if the sound goes away when warmed up, you may have an exhaust leak which is disappearing once the heat expands the metals and temporarily closes up the leak. I mention this because you said it goes away at higher RPMs which suggests to me, perhaps, that its actually going away at higher temperatures.
However, you do now know you have a broken stud. if the guys on this board are warning you, why didnt your wrench warn you of the dangers suggested above? what kind of wrench is this person?
btw, there are suggestions around, including I think, Wayne's book, that say a broken stud in the middle is not as bad as one of the outside studs.
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 09-04-2008, 05:30 PM
dshepp806's Avatar
Yes,..the "pieces' to be found from broken head studs (as they will certainly be evident, no?)
I know the guys' have suggested some Extension of longevity as to ignoring these types of failures////I wonder,,..,..but will go with the pros,..and that it needs addressing,..no?
Not sure,..but most welcome for data...
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-04-2008, 05:56 PM
RETIRED
Joe Bob's Avatar
It sounds like playing cards in the spokes of your bicycle....that and the nuts in your valve covers....are prime indicaters....
2012 ML350 3.0 Turbo Diesel
Old 09-04-2008, 06:36 PM
zbph10's Avatar
Agree with everything said here. Before I knew I had broken head studs I noticed a rattleing noise under acceleration until the car warmed up. Once it warmed up I didn't notice anything strange, maybe down in power a bit looking back.
Once I found out I had broken studs the car was never started again until repairs were made. I had 4 studs from different cylinders fall into the oil pan when I went to do an oil change and I still have nightmares about that night.
I'd question a mechanic who thinks it's OK to drive a car with broken head studs, the fix is fairly cheap right now but if one of the other three lets loose hang on to you hat.
Good luck
Brian
1987 911 Coupe-Current ride
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
1987 911 Targa-You never forget your first
Old 09-04-2008, 06:57 PM
Moke81's Avatar
Thanks for the responses, This started two days ago. Back in March when I had the valve adjustment there was one no issues with this leaking sound that I'm getting now. I will not be driving it much anymore.
_____________
1981SC Coupe
Old 09-05-2008, 04:51 AM
Moke81's Avatar
The mechanic I use is very good and would not stear me wrong. If he says it's ok to drive it and not be to aggressive with it then I believe him.
Mind you it was only one stud in the middle.
Thanks again for the responses
____________
1981SC Coupe
Old 09-05-2008, 10:34 AM
jackb911's Avatar
When you do decide to get your head studs replaced, I'd recommend a set of these...
ARP 911 stud kit. Pretty much bulletproof. Around $650.
Jack
2007 GT3
gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B
Old 09-05-2008, 08:12 PM
84toy's Avatar
Take Bill's advice or park it. Here is the 2.7 Daughter Project engine I am working on now. Pulled studs. Note the head is beat to death and beyond repair because the remaining studs would not hold it down. Also the cylinder is beat to death and beyond repair. Once one goes, it increases the load on the others and combustion pressure starts blowing by destroying things as you go.
If this engine had been repaired sooner, the costs of the rebuild would be much less. Drive it if you must but IMHO you are making a huge mistake
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 09-05-2008, 08:17 PM
efhughes3's Avatar
Henry @ Supertec sells a nice set too, available thru Pelican.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 09-05-2008, 08:45 PM
Metal Guru
911nut's Avatar
Originally Posted by Moke81 View Post
The mechanic I use is very good and would not stear me wrong. If he says it's ok to drive it and not be to aggressive with it then I believe him.____________
1981SC Coupe
Lots of mechanics say stupid things....
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 09-06-2008, 03:31 AM
what is the typical cost of doing a head stud job? certainly a job that all SC owners should plan for.
1983 911sc
Old 09-06-2008, 04:15 AM
+1
That's bad advice from your wrench. "OK to drive just don't be aggressive" is true before the cylinder leaks. You are ruining very expensive parts by running a leaky cylinder.
The pics 84toy posted above would be even worse on an SC because of the spring loaded head gasket that scores the head and cylinder when the leaking cylinder blows it out.
-Vinny
1983 911SC
Old 09-06-2008, 05:40 AM
Moke81's Avatar
This post was started to tell all that I'm hearing what I think might be another stud or studs giving way. Back in March there was no leak with one middle stud out.
I have stopped driving it and will price out the cost of a re-build.
Thank you for your concern
Barclay
Old 09-06-2008, 07:54 AM
RETIRED
Joe Bob's Avatar
3-4K....depending on what's needed and the "while yer in there" stuff that piles up. DON'T put the same crappy studs back in....buy new Raceware....
Old 09-06-2008, 07:56 AM
