polizei's Avatar
Need help with vacuum lines
Hey guys, can someone tell me if and where these nipples should be connected to? They're located above the yellow oil filler cap to the left in the engine compartment. Thanks!
Andy - 1987 911 Carrera Coupe
Old 09-01-2008, 07:19 AM
Member 911 Anonymous
DRACO A5OG's Avatar
The upper one goes to a hose that leads into the body cavity. The other is a vacumm hose and needs to be connect. You will probably find it behind the AFM area.
'85 Carrera Targa
PCA/POC
Old 10-07-2008, 11:28 PM
