-   -   Connections on CIS Injection ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/429152-connections-cis-injection.html)
P Moore 09-07-2008 03:59 PM
Hi,
Can anybody point me in the right direction here with the wiring,
This is the last job before i get the engine back in !
You can see in my clip that there is 2 blue and 1 black connecter,
This is where im mixed up....there is 2 blue and the connections are the same, and then there is 1 black, so i figured that the black goes to the black ???
But then i was looking through the engine rebuild book and im pretty sure the Wayne had a picture of the black connecting into the blue !!
Take a look at this clip and let me know.....;)
[IMG]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/XqAIaX2UAcU&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/XqAIaX2UAcU&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>[/IMG]
Jim Sims 09-07-2008 04:54 PM
http://forums.pelicanparts.com/showthread.php?s=&threadid=178079&highlight=blue+A ND+green
boyt911sc 09-07-2008 06:43 PM
CIS Wiring connections......
P Moore,
From watching your clip, you got the right connectors for the following:
Air sensor plate switch: brown and brown/red
Cold start valve: yellow and red/brown
Auxiliary air regulator: red/white and brown
These are applicable to '76-'83 (911) CIS models. What year is your engine? HTH.
Tony
P Moore 09-08-2008 03:12 PM
I was trying to find this out .....
The casing has been replaced and there is no engine number....at first i was told it was a 2.7 but from pictures i sent to a friend over there he has told me that it is a 3.0 he said he knew this by looking at the flywheel ???
So do i have these connections correct ???
boyt911sc 09-08-2008 04:12 PM
P Moore,
Yes. Based from the clip you have shown, the connectors are in the right spots. How about the 14-pin connector? If you need additional info regarding the 14-pin connector of the wiring harness just PM me. You should be ready for start-up.
Tony
P Moore 09-08-2008 04:55 PM
that should be ok as i never messed around with it !! I just took the loom off and kept it safe and re-wraped in tape,
Before i get her back in i have a MSD unit to install, i thought it would give me more room to install this when the engine is out,
I have been told i needed the following:
Msd - 6AL,
Tach Adapter (msd)
Then im waiting on the pertronix, ...getting rid of the points...
