Bringing it back from the dead..... I have a 87 new clutch less then 100 miles on it. Car idles little rattle.... It goes away when clutch is pressed in. Driving car is great under throttle in all gears quite as can be. Let off gas sounds like a 55 gallon drum rolling down the street, push clutch in goes away.
If you replaced the clutch disc with a common spring-centered disc, the rattling can become more noticeable. These transmissions were originally used with the rubber-centered discs because the rubber also acted as a vibration and noise damper. The noise is transmission mainshaft and/or pinion shaft bearings.
Ah, the coveted G50. First thing listed when selling the heavy 87-89 cars.
It's noisy when it gets old but it still is much more durable than a 915. A worn out G50 is a lot more manageable than a worn 915. G50 will keep on truckin' fairly well. Eventually a 915 will refuse to work or even worse, self-destruct. That said, i'm very fond on the 915. Straighforward to work on and works great when maintenance is attended to.
No offense, but I'm calling BS on that...the 915 is a racing derived tranny. The G50 was designed to pull the tractor trailer size 87-89 Carreras full of all their luxury add-ons. Think bloated house wife.
915's break with stout 3.6/3.8's. So how again is a 915 racing derived and a G50 is not? :) |
Nice logic Tippy...the 915 has been around for years, being refined, without gaining weight and complexity. Keep it simple stupid. Think Lotus. Dangerous, but light. Bello's car is cool.
Hi Matt...yeah ok...but I get so tired of the G50 crowd. The new guys and the car salesman types just use it as the one thing that makes the 87-89s special. My 915 is great, after 1st and 2nd gear synchros, new bushings, new wevo coupler.
Though if one wants a real race born gearbox he gets a 901. The 915 is what the bean counters made when they refused to give up on Porsche's proprietary split ring synchro for another 15 years when Getrag was already making gearboxes with Borg-Warner synchros that shifted much much nicer. |
If I was NA, I could see the benefits of a lighter 915, but I'm not. |
Hey Tippy, what year is your 3.2/G50 combo that you turbo charged? I'd like a ride in that.
http://fc07.deviantart.net/fs14/f/20...llixArtist.jpg |
Here's Ronnie!
Hey Ron, what're you talking about...that's one hot momma!
Sorry Tippy, didn't mean to spook you. I'm harmless. I do like fast cars though!
Rich, yer not that spooky, bro, and plus, Tippy doesn't scare easily!!! :D
How's it going Matt? Do you like moose knuckles like Colb and Rich do (hardy har har)?!?!?! Want more pics of such??? :) |
Ronnie,
You are spooking me! I thought you liked little boys, not big girls... |
| All times are GMT -8. The time now is 11:17 AM. |
