rhymes with targa
Bearded Viking's Avatar
Infamous G50 Rattle or something else?
I'm probably beating a dead horse......
After my 1987 911 Targa is warmed up, I hear a muffled rattling noise that sounds like it coming from the gearbox. This sound is audible only when the clutch pedal is released. When I press the clutch in the sound stops. If I drive in 1st gear and let the motor idle pull the car, I can hear the same sound. I suspected the throw out bearing.
The motor was dropped last weekend. The throwout bearing was replaced. It was failing-made lots of noise when spun. The clutch plate and pressure pad where in great shape, so they were not replaced. The shift fork was upgraded and the guide tube was replaced. I did not replace the pilot bearing.
I have updated the bushings in the shifter and it has the wrap around the shift rod located under the shift coupler access plate at the back of the center tunnel. (Followed the Excellence 'Rattle Trap" write-up) I don't think it the shifter though.
The clutch pad is the spring center type and not the rubber type. Could this be causing the noise?
I have also read about an updated slave cylinder to stop the G50 rattle.
Wil Ferch mentioned this a few years ago - Has anyone tried the updated slave cylinder?
There is a technical "tip"....shown on p.66 of the Parts and Technical Reference Catalogue..that might be worth reading :
"On 911 Carrera's from model year 1987 through 1989, to repair clutch pedal clatter ( noise that goes away when depressing clutch pedal slightly) , a modified clutch slave cylinder should be installed. The new type slave cylinder, part number 950 116 237 11 can be identified by the extended rubber boot with spring installed inside.." ( pic included in reference).
Also...same reference...p.48, there is a shift rod rattle fix described ( too long to repeat here) that essentially adds a fat rubber band ( part 999 701 969 40) on the shift rod.
- Wil
Do I just deal with it like the rest of the G50 owners?
Old 09-08-2008, 12:04 PM
dshepp806's Avatar
So, what was it doing before the changeout? Slipping?
Sounds like you've got the shifter in proper mod..and thanks for the piece on the modded slave cylinder (rattle? how's that process happen?)
Sounds like it may be mechanical, at this point,..? What? I don't know.
I get a bit of rattle in my 89 but not under load (or lugging). I, too think, mine's to do with a clutch-related problem.
BTW,..what exactly makes this noise with the throw out bearing? [[[[[QUIET=CLUTCH PRESSED]]]]]................ (not the other way around...)???
Best of luck
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-08-2008, 12:35 PM
sounds like the "rattle" my G50 makes. It has been like that for 6 years and i drive mine hard ! no problems so far. Would like to hear what others have to say about this but i wouldent worry too much
Cheers,
Ed
87 Carrera Backdate
Old 09-08-2008, 12:46 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Mine and two other friends make the same noise. I believe it's transmission main or pinion shaft bearings. But like Ed said, years have gone by with HARD driving and everything is fine, despite the noise.
Some will chime in and say clutch noise. I disagree. Another test is to idle with the clutch released. Push the gear lever a slight bit like you're going to put it in gear, but don't push it far enough to actually begin engaging a gear. I bet the sound goes away. That eliminates the clutch as a culprit and points to gear shaft (and the bearings which support them).
Kevin L
'86 Carrera "Larry"
Old 09-08-2008, 03:29 PM
dshepp806's Avatar
KTL: good point. Mine's as strong as they get....I watched a reputed P-wrench (2 years ago) , while sitting in the seat of newly bought car,..answering my questions as to this noise....he said he wouldn't worry about it at all......normal... I left with that that day,..2 years later, we're OK.
,...however,..I still say she's NOT perfect,...somehow it has to exist, no?
Best,
Doyle
Middle Georgia
Old 09-08-2008, 04:01 PM
Throw it on the ground!
- Wil
G50 Rattle or Chain Rattle? I've got both. Distinctly different sounding and both dissapear at higher rpm's. 172k on the engine, chain is surely stretched some.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 09-08-2008, 04:09 PM
rhymes with targa
KTL, yep, did that and the noise did lessen.
Today I called two local Porsche shops and they said it was normal for the G50s to make this noise.
Couple things they mentioned;
1. Check the gearbox & motor mounts. Failing mounts might increase the noise. My motor mounts are new (stock), but the G50 mounts are 21 years old and so far the only way to replace the rubber bushing is to use the WEVO repair method.
Hmm, I'm close to WEVO. Perhaps I'll have them replace the rubber bushings with ones as the same softness as the stock rubber mounts.
2. Check the drain plug on the gearbox and look for metal shavings\fuzz. Something might actually be failing.
mthomas58
Does the chain rattle stop if the clutch pedal is pressed? I would think the chain rattle would continue, if it was a "chain" rattle.
Old 09-08-2008, 04:14 PM
rnln's Avatar
I am not sure if we are having the same issue but beside the major issues I posted below, I also have the rattle noice at the transmission once in a while. It could be produced at lower RPM. The rattling noise can be described as you are putting some pieces of metal chain into a metal jar and shake it fast, as the rythm of car running.
Scary noise and thump when engaging torque, tranny/clutch/engine??? please read.
BTW, I bought my car to AASE today and Jeff said it is my rubber disk clutch is gone. Probably the rubber is completely separate from the clutch disk. It need a new clutch disk and new spring center (930-116-014-02). He quoted me $1,3xx. He added it will be more because when the engine/tranny is comming off, there will be more parts need to be replaced. But basically, it's the clutch problem.
Fat butt 911, 1987
Old 09-08-2008, 04:26 PM
mthomas58
No, the chain rattle is only under load, only when engine is hot, and only at 2,000 to about 2,500 rpm, and then is goes away. No chain rattle when engine is cold.
Mark
1987 911 Coupe
Old 09-08-2008, 04:37 PM
KTL KTL is offline
Schleprock
KTL's Avatar
BV,
I don't think engine/trans mounts are going to transmit that kind of noise unless they're completely torn. The mounts in these cars are pretty robust, so it's easy to see when they're failed. The trans mounts can be replaced with rubber- you just have to buy a complete replacement alloy crossmember, which of course is not cheap. And you'll always find some semblance of fuzz on the drain plug magnet. The synchronizers operate via friction and thus some synchro material very fine particles are always going to end up in the gear oil. Plus, if you have a LSD, you'll get wear particles from the friction discs in the oil as well. So fuzz a bit of on the magnet doesn't necessarily mean problems are present. A monster fuzz ball and big metal chunks on the magnet means there's a problem in there!
rnln,
I'd be wary of what AASE says if you do the test I mentioned and the sound goes away. A damper completely separated from the disc would not operate smoothly whatsoever and would destroy itself fairly quickly, thereby killing your clutch operation altogether. But if you think you need a clutch anyway, have them do it. Still, i'd ask to see the clutch disc when they do the work to confirm their diagnosis. All you do is put the rubber damper in a large vise and then twist the disc with a couple of Vise-Grip pliers clamped on the disc itself. You'll see right away if there's any location where the disc damper is compromised. Ask them what else they think needs replacing. I know standard practice is to replace most every clutch component "while you're in there." But there's nothing that says you can't replace just the disc alone and put it all back together. There is no part in the clutch system that is a one-time-use-only part that cannot be reused when removed from the car.
I'm certainly not saying the rattle in neutral at idle is PERFECT. Just saying it's a typical characteristic of these transmissions and it does not mean terminal failure is coming soon. I don't like it any more than you guys. Still, i've been driving my car hard for ~3 years at the track and it's still holding strong, performing well. A friend has 160K (I have 83K) on his G50 and drives it like a top fuel dragster- same noise, no worries of impending failure. He's a automotive tech, so he knows when there's a problem brewing inside a trans.
Kevin L
'86 Carrera "Larry"
Old 09-09-2008, 11:21 AM
Registered Cruiser
jorian's Avatar
I bought my 87' with 75K miles, now have 141K miles on the clock and drive hard. No issues at all except for the rattle. I'm going to leave it until I rebuild the entire box.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 09-09-2008, 12:09 PM
rhymes with targa
Thanks for the replies.
Question for those with a G50 gearbox.
What gear oil have you been using?
I'm wondering since this sound occurs after the car is warmed up, if a thicker gear oil, like mobile 1 90w-140 synthetic would help lower the volume of the rattle???
Old 09-09-2008, 12:27 PM
burgermeister's Avatar
I think it's just gear rattle. Mine does exactly the same thing.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-09-2008, 01:53 PM
dshepp806's Avatar
So MANY types of rattles, no? I've time trying to differentiate these "rattle anomolies",
.,.....studying the shifter mech articles,...all made sense,..techniques applied...fresh HW in there......
understanding the idle gear vibrations when placing her at low RPM in first (or, worse, lugging in second,..DD stuff) and hearing this idle gear vibration "rattle".......AGAIN, another "type"....and then:,...the bigees:
clutch-related/TB issues (mechanical).......seems to me that any/all could contribute to silence (?) or not.....this is the area I pay attention to,..from the wrenches at bay here,..for they've been there,..and know from where these noises are sourced......all silenced with clutch depression,..........again,..what "makes" THIS noise? (patience, please.)
SO many threads out there on this.,....what a definitive holostic thing........thanks to all who share this mechanical knowledge. The P-wrench (and others here) say not to worry,..although I ask specifically, what is making this noise (parts?)
I'm up for a fluid change, too. Ordering new HW now.......she sure shifts good now,........so , after 2 years, it's time to change the fluid....
JW had some good threads on this,...
Best,
Doyle
Middle Georgia
Old 09-09-2008, 03:33 PM
My '87 did this as well if I didn't release the clutch smoothly when starting out or lugged the engine at low speeds. Wasn't there a TSB for a brace to be added to the heat exchanger to address G-50 / HE rattle that was later incorporated into the late '88 cars?
Old 09-09-2008, 07:33 PM
I'm here to cause trouble
jimbauman's Avatar
For what it's worth, I have an '86 with a 915, and it makes same noise too. It's only audible when the clutch is released. I have solid mounts all round so the noise is *really* amplified.
JB
Old 09-16-2008, 04:17 PM
I use Mobile Delvac 75w-90 synthetic gear lube. Billed as the Porsche factory fill for all Borg-warner equiped transmissions.
Couldn't find it on Pelican. Do a web search to find sellers.
Old 09-16-2008, 04:52 PM
rhymes with targa
Thanks, ordered a gallon from here;
http://www.lufteknic.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=Mobil75-90delvac&Category_Code=lubricants
Old 09-16-2008, 05:20 PM
Registered Cruiser
jorian's Avatar
IIRC the 'G' in G50 stands for Getrag. Swepco makes a specific gear oil for these trannies. That and the Delvac mentioned are good.
Old 09-16-2008, 05:31 PM
rhymes with targa
I don't think this will fix the rattle I'm hearing, but since my engine was dropped a couple of weeks ago, I'm going to give it a shot anyways.
Posted last winter by MBEngineering.
Engine vibration at 3000rpm
Originally Posted by MBEngineering View Post
HI Anthonycanada
you could try this,
taken for educational purposes
is there any noise at idle, from the transmission?
regards mike
Old 09-21-2008, 04:02 PM
