awdbandito's Avatar
MFI fuel pump relay questions
In testing the socket where the red relay plugs in #30 goes to the fuel pump, what voltages should I get from 87 and 87a when cranking and when the air sensor plate is lifted?
Also, which terminal should have a constant 12V?
I'm not getting 12v down to the fuel pump, but if I feed 12v into terminal 30 on the socket then I do get power to the pump and can start the car and drive it.
Old 09-12-2008, 06:16 AM
Peter Zimmermann's Avatar
"MFI" or "CIS?"
Keep the Shiny Side UP!
Pete Z.
Old 09-12-2008, 08:36 AM
304065's Avatar
There is no relay for the fuel pump in an MFI car.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-12-2008, 08:56 AM
awdbandito's Avatar
It is a '77 carrera 3 and I thought it was mechanically fuel injected. I have a red relay under the hood that is labeled 'fuel pump relay'
Old 09-12-2008, 12:47 PM
