87 Carerra, 3.2 liter en
Help} Starting Problem
CAr was running fine. But I was doing some work in the battery capartment installing different headlights and now all of a sudden the car just cranks and will not start.
I checked the dme relay under the seat and I believe it is okay. But what really baffles me is that I put a test light on the fuse that controls the fuel pump and I get nothing. When I touch the other fuses I get a light and sound menaing that power is flowing thru those fuses. However, when I touch the fuse and post that controls the fuel pump, it is dead. I have changed six fuses with no help.
Will you guys direct me as to where i can start to address this. I believe it starts with the fuse box. Any suggestions will be gratly appreciated. As you can tell from my writing I am not that mechanically inclined
Old 09-16-2008, 03:03 PM
dshepp806's Avatar
Tell us more of your "battery compartment headlight install".....
Have you a voltmeter?
"How" was the DME relay checked? Was it changed (period) ?
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-16-2008, 03:27 PM
Doyle:
I had a guy come in and put some HIDs in my headlights.
I took the DME Relay and separated it a little bit so I could see the pins. I then held a light tester on pins 87 and 87b and I got a light and sound on both. So I assumed that the DME relay was fine. But that may not have been suffieicent.
I do not have a voltmeter. But I will go over to sears and get one if that is what you sugrst. What should I look for in getting one. Ztell me what to buy and I will get one.
I am wondering why when I was touching with the light tester the fuse that controls the fuel pump I did not get any sound or light when the other fuses gave off a signal. Does that suggest anything.
Please direct me in trouble shooting this matter and I will do what ever you say
Old 09-16-2008, 03:46 PM
