Carrera USA/EURO
What is different?
I know that compression USA is 9.5:1 and Euro is 10.3:1
Where is difference?
-crankshaft
-rods
-cylinder
-piston
-head
Old 09-19-2008, 03:59 AM
Bill Verburg's Avatar
If you ar asking about '84-89 3.2 Carrera, the diffference is in the pistons/cylinders, exhaust and DME parameters.
All the Euro 930/20 or /26 w/ 10.3cr used forged Mahle pistons w/ Nickasil cylinders, the 9.5cr 930/21 or /25 used either forged Mahle or cast Kobelschmit Alusil
the 930/20 has a pre-muffler the others a cat
Bill Verburg
Old 09-19-2008, 04:20 AM
Well ,but why the reference cylinders in PET is the same for 930/20/21/26?
Old 09-19-2008, 07:19 AM
They may be physically interchangeable as sets but the fact of the matter remains, at original assembly the 231hp 903/20s all got forged Mahle 10.3 w/ Nikasil cylinders, all the others got either 9.5 forged Mahle/Nikasil or cast KS/Alusil. Which you got was hit or miss w/ the purported preponderance of KS going to US cars
Bill Verburg
Old 09-19-2008, 07:34 AM
But the difference of material doesn´t mean that the CR is different.
There must be any difference in height piston or cylinder,and reference is de same in PET
Old 09-19-2008, 09:17 AM
That's correct, but the 10.3 pistons are all forged Mahle and are used w/ Nickasil cylinders
and
the 9.5 pistons can be either forged Mahle(w/ A lower piston top to give less compression) or KS cast. The former will have Nikasil cylinders and the latter will have Alusil.
I don't understand what is so confusing about that.
for the Mahles there were 4 different weight classes for 930/20/25/26 and 4 more for 930/21
for the KS there were 4 more different weight classes only used on 930/21
on the production line the spec is to have all pistons w/i 4 g, for service afterthe fact the spec is to be w/i 8g
Bill Verburg
Old 09-19-2008, 09:37 AM
Warren Hall Student
Bobboloo's Avatar
What is different?
-crankshaft
-rods
-cylinder
-piston
-head
The pistons are what made the compression difference. They had a higher dome. The crank, rods, cylinders and heads all had the same dimensions for both Euro and USA.
If you wish to change the compression just make sure that you match Mahle pistons to Mahle cylinders or KS to KS. They can't be interchanged between the two brands.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 09-19-2008, 10:54 PM
