wannabee wannabee
WIL84911's Avatar
HELP with SSI oil lines
installing SSI's. got the 2 replacement hoses but can't seem to figure out where they go. thanks!
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 09-19-2008, 06:09 AM
Bill Verburg's Avatar
They should go like this
Bill Verburg
Old 09-19-2008, 06:46 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
what part number oil lines do you have?
maybe this can help...
http://www.pelicanparts.com/911/911_Parts/1974-75/1-6-1.JPG
edit,. Bill beat me by a minute!
Old 09-19-2008, 06:48 AM
mca mca is offline
mca's Avatar
The hard line connects to the side of the case and is mounted at the oil cooler on the front of the engine:
The flexible line connects to the other end of the hard oil line where the hard line mounts to the oil cooler on the front of the engine:
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 09-19-2008, 07:19 AM
rattlsnak's Avatar
if you got these in a kit, you probably have the flex line that routes over the top of the trans and not under it, like the hard line does.
Old 09-19-2008, 02:33 PM
wannabee wannabee
WIL84911's Avatar
Thanks for all replies!
Got the solid line part 911-107-739-10-M20 and flexible line 911-107-728-00-M20 (thought I did not have a front oil cooler). Should I have gotten 911-107-729-10-M20 (w/ front oil cooler) instead?
Anyways I was at the shop at the time and my mechanic instead made modifications to the existing lines to make them fit. I will probably made the correction at some point.
But now regarding the heater hoses, how did you reconnect those? Left them open for now and I'm guessing I would need to run 2 flexible hoses into that same single duct. Is this so?
Old 09-19-2008, 06:00 PM
