Removing rear badge emblem?
Does anyone know the best way to remove the rear badge emblem with the adhesive backing? I need to replace mine and I don't want to damage the paint.
Old 02-15-2009, 10:12 AM
the the is offline
Heat it up with a hair drier and it'll pull right off. You can saw it off with some strong dental floss if needed.
Old 02-15-2009, 10:34 AM
Great idea... never would have thought of that.
Old 02-15-2009, 11:10 AM
m110's Avatar
Dental floss (heat helps)
Goo gone or equivalent to remove residue
Remember to use some good glaze/polish and wax afterwards
I left mine off for a cleaner look, I don't need to advertise
1988 Carrera Coupe
Old 02-15-2009, 01:16 PM
I may do the same... thanks m110.
Old 02-15-2009, 02:07 PM
Wickd89's Avatar
after removing.
Spray some goo-gone and it works the remaining glue off.
Then use some Scratch-X to get rid of the dirt that built up around the emblem.
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 02-15-2009, 02:16 PM
