e p slick's Avatar
Wtb Fuel Distributor Rebuild Parts
Anyone know where I can get fuel distributor rebuild O-rings, Stainless body gasket and barrel anti-rotation washer/lock. The folks in Texas - DeLorean - say they only sell rebuilt units and not parts.
Any help appreciated.
EP Slick - Tucson
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 07-07-2008, 08:19 AM
dlagerstrom's Avatar
From what I understand, that is the typical response. The rebuilders seem to hold this info very close to keep their business. I don't think there is much to rebuilding, but getting the parts is basically impossible.
If you find a supplier, please let us know.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 07-07-2008, 08:46 AM
e p slick's Avatar
Will do
Will do
Old 07-07-2008, 09:10 AM
GothingNC's Avatar
Here is a fuel distributor rebuild link that lists the o-ring sizes.
He picked up the o-rings from a local hardware store.
http://www.porsche928forums.com/download/manuals/CISRebuild.pdf
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 07-07-2008, 09:34 AM
e p slick's Avatar
Gothingnc
GOTHINGNC - Great article - thanks.
EPS
Old 07-07-2008, 09:45 AM
I am not an expert but I believe cleaning and replacing parts it just a small part of a rebuild.
The important part is adjusting the flow rates in total and to balance each of the ports.
This requires a special bench set up to do it.
You might be able to rig something up with a fuel pump, WUR, power, injectors and measuring beakers but sounds like a lot of effort.
Get it wrong and you may burn a valve or piston.
Best of luck.
Old 07-07-2008, 03:48 PM
searching too...
I've been trying to source the metering plate also...
Have you had any luck?
Old 09-23-2008, 11:25 AM
You should be able to source the o-rings at www.mcmaster.com. Did you lose your washer? If not you should be able to re-use it along with the stainless gasket. I rebuilt my fuel head because the car was sitting for a long time and I did not want to run the re-built engine without knowing it was good.
After taking it apart, cleaning, and putting it back together I then tested the flow rate with the injectors in the car using glass beakers. I could not get different flow rates no matter how hard I tried.
1980 SC
71 Chevelle SS454
Old 09-23-2008, 12:51 PM
Thanks Mathew,
I have everything but the plate.
The stainless metering plate has rusted away... Stainless - not rust proof...
I have three cylinders that have holes in them. When pulling plugs I ended with 3 beautiful clean ones, and three very rich ones.. :-(
Hence - I am looking for a new one, or used one out of a "no core" 006 fuel distributor.
I will have a few machined if need be, which might help others, and the cost of three is close to the cost of one. I thought I'd try sourcing them first.
Thanks,
michael
Old 09-23-2008, 03:42 PM
