78 911 SC trailing arm bushings issue
I am putting this car back together and I have a problem with the Neatrix rear spring plate bushings. The outer fits into the cover plate and over the T-bar cover fine. The inner does not fit in the corresponding bushing well in the car. The well on the car is conical and the bushings are cylindrical. I test installed a set of conical rubber OEM bushings PN 644-333-131-00 but they are too small in dia resulting in play and what is worse, the spring plate bolt heads will rub against the body. I really d/n know what to do here.
Thanks in advance for your help
Rob Caso
Failure is not an option
78 SC, 06 Cayman S, 74 Targa, 1971 BMW R75, 1975 BMW R90S, 1983 BMW R100S, 2004 BMW R1200GS, 1974 Ducati 750 GT, 1974 Ducati 750 Sport, 1986 Ducati MHR Mille, 1995 Ducati 916, 1994 Bimota DB2, 2001 Tri 955 RS, 1970 Norton 750, 1975 Hon 400 F, 1971 Hon 750, 1967 Duc 250, 2016 Tri Thruxton
Old 09-24-2008, 11:31 AM
Tags
sc trailing arm bushings
