Help Identify the type of 911
:confused:Recently I bought a 911 from the father of the original owner an Army Captain that herself told me she bought it in Germany. The car is in excellent condition in and out everything originall. What I learned is thanks to all Fellow Pelicans. Here are the facts.
2.7 engine code 6372802 vin. # 9117311396 Targa, Turbo Look Spoiler No gas pump, No Air Condition Fabric Interiors, manual windows radio antenna at driver side fender alternator 5 blade fan # 9011061015R Reinforce crossmember as carrera front and rear stabilizing bars 5 SPEED, stnd. flares in back (someone said there where sc flares Manuals go up to 74 2.7 and 78 and up 3.0 so What should I used Only manuals that I have are: Haynes and 101 Projecs and you, Masters!!! :D http://forums.pelicanparts.com/uploa...1222219232.jpg http://forums.pelicanparts.com/uploa...1222219268.jpg |
One last Question: It is a 911S or 911? |
This old post from Grady might help a little:
And then there's this page:
http://www.0-100.it/porsche/welcome/welcome_italiano.htm Go to the menu item "NUMERI DI TELAIO PORSCHE 911" It's in Italian, but still theres lots of info to be gained. |
pr944may
You should consider upgrading that fan to an 11 blade one, in PR temps are playing against you. And if you can afford it a carrera oil cooler. Just my 2cents. |
Albert,
Perfect color for Colegio!!! |
the RoW line up was; 911, Carrera 3.0, Turbo, your's being a RoW was just a 911 w/ 911/81 engine and 915/60 5 speed In the US the lineup was; 911S, turbo, the 911S used 911/85 engine and 915/61 trans Both 911/81 & 911/85 are rated 121hp@5800, 235ft-lb@4000, 8.5cr |
Make sure it doesn't have the exhaust thermal reactors under the engine (don't know on ROW cars - US only, I think), and you may get by w/ the 5 blade fan (11 blade is a really good idea, though). Make sure you get the correct diameter 11 blade (couple different sizes).
Don't know if the '77 ROW cars had front oil coolers or not. Look inside the RF fender in front of the tire by the horns. If it has a trombone cooler, it might be adequate depending on your driving style. |
http://www.elferhelfer.com/fzident.htm# |
| All times are GMT -8. The time now is 09:57 PM. |
