Alan L's Avatar
ignition charge light wont go out.
I have pulled my SC motor and stripped it down to short block. I left the alternator and shroud on to pull the cylinders. I just lifted the shroud enough to clear the engine.
Now the engine is back in . Fired first crank, running sweet. But the charge light stays on. It is a while since I pulled an alternator off, but from memory, those terminals are held on by nuts?
Are there any terminals under the shroud I could have dislodged to cause my charge problem.
Where else should I look.
Got to be a dislodged wire (hopefully not under shroud) or misplaced one.
Thx
Alan
Old 09-25-2008, 11:50 AM
mca mca is offline
mca's Avatar
Don't take offense ... but double check the tension on your fan belt.
Have you taken it for a drive and brought the RPMs up? If the light goes out with increased RPMs, there is a good chance the belt is too loose.
I put my fan on a new engine and didn't change the shims. Got the red light and figured I messed up the wiring at my alternator. After pulling it twice and finally having the alternator bench tested (was good) I realized that my belt was 1 shim too loose. I felt pretty stupid - especially for wasting so much time.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 09-25-2008, 01:09 PM
Alan L's Avatar
Sorted - my solution was even dummer. (No offense).
Had the solenoid wired wrong. AAhhh.
At least don't have to touch alternator.
Thx
Alan
Old 09-25-2008, 01:13 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Good job Brother! So many things to remember.
'85 Carrera Targa
PCA/POC
Old 09-25-2008, 03:56 PM
