Another suspension question
Hi there
i would like to replace the old suspension on my 76 911 targa and need your help with the technicals terms please (english language problems too) . anyway, although i drive my car only in public streets i love the hard ride of the car. could u please tell me what do i need to change (part numbers welcome otherwise just the part name with description ) ? what about installing strut brace? what about tie rod (turbo or not)? what about Bump Steer Kit for 911 ? what bushings / valves etc. i need? dont want to go crazy with it but want the car to ride like a new one
911 TARGA 1976 - 3.2L, G50 SHORT BELL HOUSING. Toyota Hilux 4x4 2000 VW tuareg 2009 3.6 HONDA SH350 |
worth it after everything else is done yes for a lowered car, these range from simple $10 steering rack shims to $400 steering arm kits, which you need depends on how low the car is, the simple kits are ok for most street uses Quote:
To me a lowered factory C3 w/ 7(8) & 9x16s, w/ factory rubber bushes, t-bars, sways is a perfect street set up.
Friend of Warren
You might also want to look at Pelican Part's Suspension Wizard which will take you step by step through your suspension and gives some excellent suggestions on what will work best on your car. http://www.pelicanparts.com/cgi-bin/wizards/parts_wizard.cgi?wizard_root=911_suspension_wizard
Kurt V No more Porsches, but a revolving number of motorcycles. |
Bill, I think you're right on the money here. I'm in the process of replacing all the bushings in my car with OEM replacements, the only ones left to do are the A-arm bushings, and the front ball joints. Even with just the stock T-bars, 8x9x16" Fuchs, A-arm bushings rotated, All new sway bar bushings and drip links front and rear, new rear trailing arm bushings inside(OEM) and out(Neatrix), and lowered just a tad below "euro ride height", the car is a dream to drive; I use it as my daily driver, and it deals very well with bumps in the road, and glides along solidly yet smoothly over all other pavement surfaces. Porsche knew what they were doing when they engineered the suspension in our cars.
- Everything's easier once you get started. - '95 993 C2 '73 911 Targa '88 BMW M3 '84 Mercedes 190e 2.3 16v |
AutoBahned
AutoBahned
your '76 is decades old
replace every piece of rubber on the car... that will greatly improve the ride and the handling and will keep you out of trouble for a while too |
At the track = great day
I completely agree with this, I just had my suspension redone and the rubber in it was just rock solid. I know this sounds bad, but check you motor and transmission mounts too while you are at it. I know mine were completely shot.
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
thanks ill do some search here and order the parts i need
can i do it alone or do i need special tools? i have most of the tools as i work on my mx bike too...
AutoBahned
a few sp. tools may be needed [ball joints] but as long as you have bigger stuff than for a bike you should be set
numerous threads on everything you need to do |
