scottbombedout's Avatar
996 Brakes on a 3.2 Carrera?
http://cgi.ebay.co.uk/Porsche-911-996-Turbo-Discs-and-Calipers-Big-Red_W0QQitemZ220278254400QQcmdZViewItem?hash=item2 20278254400&_trkparms=39%3A1%7C66%3A2%7C65%3A1%7C240%3A1318&_trksid=p3286.c0.m14
996 brakes seem to come up on ebay a lot.
Has anyone ever fitted these onto a 3.2 Carrera or would there be too much work involved?
Hurry up with your replys, only got a couple of hours to go
88 carrera
Using the teutonic shift method since 1990.
Old 09-13-2008, 04:20 AM
Bill Verburg's Avatar
those are 996tt, they are a little big for use on a 911. But the parts to use them can be purchased from Steve Timmins
I would like to see something to use regular 996 brakes on a 911, but haven't to date.
Bill Verburg
Old 09-13-2008, 05:40 AM
175K911's Avatar
Steve's stuff is pretty nice. My BIL did this brake conversion on his 3.6 SC and can go so much deeper into a turn than I can but has to be careful not to lock up the fronts.
Big challenge is that 17" wheels are required for this conversion.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 09-13-2008, 05:49 AM
As I said they are oversized for the application and they do have a lot of front bias, I have 993RS on my early C3 mit 3.6, they are slightly smaller but still overkill, A normal SC/Carrera is really happy w/ something in the 3.3 930 to GTP-L range which is where the normal 996 brakes fall
Bill Verburg
Old 09-13-2008, 05:56 AM
Ah yes. I initially thought 996TT brakes would be a little overkill/heavy on my car too. Especially with relatively skinny tires (225 F & 255 R), it didn't seem to be worth the extra weight penalty.
Dr. Timmins said in an email to me (as a result of a direct enquiry as to using 996 brakes) that he was sure he could most likely supply any combination required to use regular 996 (aka Boxster S) monoblocs front and rear.
I hope he won't mind me quoting him here, I shouldn't think so:
1) The 993/996/996tt/993tt/928S4 etc. front rotors all fit my hubs.
2) The 996 front calipers can use the 993 adapters with some minor machining
3) The 996 and 996tt rear calipers fit the same adapters
He also pointed out that there was a huge difference in thermal capacity and pad area between 996 and 996TT and that his preference was strongly for either 993TT or 996TT - which is what he fits to his own cars.
'77 S with '78 930 power and a few other things.
Old 09-14-2008, 02:24 AM
That's good to know. As always the devil is in the details, in this case which rotors are going to be used.
I am not a fan of 3.2 Carrera 24x283 except as a minor upgrade to stock SC(20x283 & 20x290) in the front only w/ 3.2 Carrera front calipers. JMO, but using Boxster front calipers is not a good thing to do.
I am a huge fan of 3.3 turbo rotors all around, they use 304x32 & 309x28 rotors and are great w/ any caliper set that can be adapted to them, that includes 964, 993, Z haus 917.
In between the above 2 choices are Wevo(not available commercially but the prototypes were fantastic) which use 315x28 & 309x28 rotors, GTP-L which use 313x28 & 305x28 rotors, oem 964 which use 298x28 & 299x24mm rotors and 996/Boxster S rotors which use 318x28 & 299x24. Any Calipers that can use these rotor sets is going to be perfectly adequate for a normal run of the mill SC/Carrera.
On the overkill side are the 993tt/RS rotors @ 322x32 & 322x28 and 996tt rotors @ 330x34 & 330x28mm. These do work I have the 993RS on both of my cars and the brakes are never an issue, they stop well and have decent bias(some better that others)
An issue that I have w/ many DIY sort of brake upgrades is using a caliper designed for a bigger rotor on a smaller rotor. These sort of arrangements lead to overheated rotors and caliper piston hyper-extension.
Steve is correct that there is a large jump in thermal capacity(which is what you really want) between each of the 3 general size groups
small '69-89 911/Carrera
medium Wevo, GTP-L, 964, Boxster S/996
large 930, 993RS/tt, 996tt
and there are differences within a general grouping.
The question is what do you need on your car
early cars through 2.7RS and especially lt/wt versions are perfectly happy w/ stock 911S/A as the cars get heavier and faster the need for bigger brakes(actually rotors) goes up.
Again JMO but anything bigger than 930 isn't needed for 99.999% of all 911s
Bill Verburg
Old 09-14-2008, 09:46 AM
Bill, I've been meaning to ask forever - is there a "back of envelope" calculation that will arrive at a bias figure based on piston size(s), rotor diameter and pad size (if that's even relevant to anything other than heat capacity)?
And, if such a formula existed, what would be most desirable for the various usage (e.g. street, DE, AutoX)?
Thanks.
Old 09-14-2008, 12:12 PM
bias is primarily a function of front piston area divided by rear piston area.
rotors are usually about the same, a bigger effectiuve radius increases bias at that end by a relatively small amount
pad compound is also a factor, pad area is not
desireable bias depends on chassis/suspension setup, lsd, venue, driver preeference
A/X generally wants more rear, track generally less but chassis/supension, lsd, driver preference has a big influence too
Bill Verburg
Old 09-14-2008, 01:14 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I had them on my 72 RSR clone, and they worked fine. I got the rear kit from Timmins and had to grind about 1/8" -1/4" of metal of the bottom corner to make them fit, but otherwise no issues.
Old 09-14-2008, 02:51 PM
Send a message via Yahoo to Lukesportsman
I've been trying to source adapters from Dr. Timmons for almost a year. He is having some real issues with securing the parts from his machine shop. It's driving me crazy walking by these beautiful brakes only to see them continue to sit.
If anyone has another source for adapters, I'd love to hear. I'm running 245/295 Pilots and will be trying this with Chuck's new rear suspension if I can ever source the adapters.....urgh.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 09-15-2008, 07:21 PM
Jaskas's Avatar
Im also considering a 996-type brake update, but im still a bit confused about the fittings?
Option no.1
- 996/boxsterS front calibers and front rotors to my front
= I only need a adapter for the caliber?
- 996/boxsterS rear calibers and rear rotors to my rear
Option no.2
- 996/boxsterS rear calibers and original C3,2 rotors to my FRONT
Im a right about the rotor sizes?
The Carrera 3,2 discs are:
- Front: 290mm/24mm
- Back 282mm/24mm
The 996/boxsterS rotors:
- Front: 318mm/28mm
- Back 299mm/24mm
911-87 mit der 3.6 V-Ram und alles spaß
Old 10-03-2008, 02:21 AM
shahram's Avatar
I don't think you can go with 996 or Boxter rotors.
If you cosider using 996 calipers than the best way is to combine them with
front and rear 930 rotors, well this is how I did mine.
Old 10-03-2008, 04:55 AM
GrantG's Avatar
Bill of the above, are the Carrera and 930 brakes the only ones that can fit under 15" Fuchs?
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 10-03-2008, 07:46 AM
AFAIK + of course the new Zuffinhaus 917s which are essentilly 930s
Bill Verburg
Old 10-03-2008, 11:05 AM
GrantG's Avatar
Thanks!
Old 10-03-2008, 12:06 PM
