At the track = great day
ChkbookMechanic's Avatar
Installing an oil cooler fan on an '84 Carrera
I know PP has a tech article on how to install a fan on a Carrera-style cooler for the SCs using stock parts to make it look factory. However, I had an aftermarket cooling fan relay and a Carrera whose fuses aren't the same as an SC. So I thought I'd give a quick rundown on what I did in case anyone else comes looking and perhaps my wiring adventure can at least help someone.
The aftermarket cooling fan relay is the one sold by Elephant Racing. It has the ability to control two fans and can handle a max of 25 amps between the two fans. It also has the ability to turn the fans on automatically when the a/c kicks in (or when you choose to wire a switch inline on this wire). I installed the fan onto the oil cooler using the instructions that came with the fan and then installed the probe into the cooler as the relay's instructions described. The relay itself was positioned in the front of the trunk underneath the trunk latch.
For the fan (Perma-cool puller):
  • The 12V wire from the fan is connected to the 12V+ on the relay for fan 1.
  • The fan's ground was grounded to the chassis.
For the relay (Derale #16759):
  • The constant 12V was connected directly to the battery and had a 25amp fuse inline to the relay
  • 12V lead for fan 1 was connected to the installed fan using a quick connect/disconnect connection
  • The relay's ground I extended and then grounded it on the ground above the fuse box in the trunk
  • The 12V switched wire I extended and then attached to fuse 7 relay panel 1 (25amp windshield washer/wiper fuse)
  • The 2nd fan 12V wire was just wrapped up and tucked away
  • The a/c clutch line is currently not connected to anything, although I could easily run a wire from fuse 7 to a switch in the cockpit and then to the relay I haven't just yet.
I debated on which fuse to use for the 12V switched and the Bentley manual gives conflicting information as to which fuse does what (fuse 6 and 7 are switched between their diagrams and the list of the fuses control later in the chapter) so I went with what my fuse panel said and picked the fuse that had components that I used least and knew had 12V switched power.
The wiring was extended using quick connect/disconnect fully insulated connectors so if I ever feel that I need to rearrange the trunk I can easily move the relay and just have to cut new wires to the new length.
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Last edited by ChkbookMechanic; 10-01-2008 at 03:41 PM.. Reason: Added name of relay used
Old 09-30-2008, 06:55 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Nice Write Up!
'85 Carrera Targa
PCA/POC
Old 09-30-2008, 07:16 PM
slodave's Avatar
Do you have any pics? You have the brass cooler right? I have been thinking of doing something like this as well, but, since the driving goes down in summer time, it's back on the list of things to do. Thanks!
Old 09-30-2008, 07:42 PM
DRACO A5OG's Avatar
Hey Dave,
I love to be your helper when you get around to doing the upgrade. I too been thinking alot about this.
Jim
'85 Carrera Targa
PCA/POC
Old 09-30-2008, 07:48 PM
I'll see about adding pictures tomorrow, it is a tad dark right now. I have upgraded to one of the widemouth carrera oil coolers since the cooler that came with my car was original and leaking profusely. The entire process is pretty easy but the wiring took me about 30 minutes since I wanted matching colors on the wires along with clean wire routing.
Lane
Old 09-30-2008, 07:49 PM
slodave's Avatar
Originally Posted by DRACO A5OG View Post
Hey Dave,
Jim
Jim, you are more than welcome, but you may be an old man. It is something I was considering as a temporary fix for my crushed oil line. Temps only get to about 9:00, but it would be nice to have for the occasional traffic jam, long fast food line...
Old 09-30-2008, 08:20 PM
slodave's Avatar
Thanks. I thought that you might have upgraded the cooler. I was hoping to get some ideas on how to mount the fan/s on the brass cooler. Pics are always nice though!
Old 09-30-2008, 08:22 PM
The fan comes with zip ties that you run through the oil cooler rows. I'm sure you can use them to get the fan to mount onto the brass tubes on the cooler rather easily.
Lane
Old 09-30-2008, 08:49 PM
DRACO A5OG's Avatar
Crushed Lines & 9:00 +1, Hey I had to read twice, I thought you were saying I am an old man. LOL. Well, I guess I am
'85 Carrera Targa
PCA/POC
Old 09-30-2008, 09:17 PM
Here are some pictures of my install...
This is where I pulled the 12V switched from
Here is where I grounded the relay
Here is how I routed the 12V switched, ground and 12V constant to the relay
And here is where the 12V to the fan and temp probe find their way out of the trunk
Here is how the fan and probe are mounted.
And, in all its glory the relay and my wonderful temporary mounting position
Just for the heck of it, a picture of the fan as through the Pelican Parts scoop..
Lane
Old 10-01-2008, 03:38 PM
DRACO A5OG's Avatar
Very Cool (sorry for the pund)
Can't wait to do the up on my baby.
Thanks for the pics!
'85 Carrera Targa
PCA/POC
Old 10-01-2008, 04:38 PM
