Help needed to ID WEBER carbs
Today I picked up a pair of Weber carbs.
40IDTP13C 1235 stamped below on the float bowl
40IDTP13C1 1550 stamped below on the float bowl
Why the C on one carb and C1 on the other? And the different numbers on the float bowls?
Can anyone tell me what model 911 these are from.
The fellow whom I bought them, said they came from a 1969 911 T and would need some work. Hence the PP of $200.00
The finish is exquisite! A light green/ brown. No stains nor scratches or buggered up screw heads. The throttle shafts have a very small amount of play, so I'm wondering, send them off to be repaired or is a small, very small amount play okay?
Old 10-05-2008, 08:27 PM
...........bump...................
Old 10-07-2008, 06:03 PM
BURN-BROS's Avatar
"3C" designates it has 3 chokes/venturies. The "1" designates that it is assembled mirrored...IE, one left and one right.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 10-07-2008, 10:45 PM
Wer bremst verliert
JohnJL's Avatar
If they are any good that's a massive deal.
Slap them on and see if you ahve any leaks from the shafts.
Not sure what models came with them but it was around 1969-1970.
In any case at $200 you have ~$3000 to work with before you end up at what a new set of PMOs cost.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-08-2008, 02:23 AM
Grady Clay's Avatar
Augustus,
Check this thread.
Weber Carbs Diff Between IDA IDT IDTP
I'll buy them if you don't want them That is a GREAT deal!
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-08-2008, 08:32 AM
