JeffO's Avatar
Which Dremel bit for exhaust nuts?
Tomorrow I get my SW chip and cat bypass from Steve and figured I would take off the old cat beforehand. I got five of the nine off with normal tools, sweat, and a bit of blood. But the last four will have to be cut off. Would anyone recommend a 1.5 inch cutoff wheel, die grinder, or the fiberglass disks. Or is there a better way? I do not think a nut cracker will fit and a chisel seems extreme. Thanks in advance and I will post my seat of pants dyno results after it is completed.
"The smaller the fine print, the larger the risk."
1988 911 coupe
2008 VW R32
2004 530I
Old 10-01-2008, 03:29 AM
My exhaust nuts laughed at me when I attempted to use a dremel. If you don't have heat (Oxy), can you take them to a muffler shop and let them remove the nuts? I used a combination of die grinder, drill, and lot's of cursing many years ago (I didn't have "heat" at the time)
Old 10-01-2008, 04:00 AM
At the track = great day
ChkbookMechanic's Avatar
The dremel might not be strong enough, but I'd go after it with a cutoff wheel. The key to remember is to not force the dremel down onto the bolt. You have to let the cutoff wheel do its job.
I just installed my SW chip and m&k cat bypass last weekend and finally made the last bit of adjustments to the idle yesterday. I am very impressed by the chip.
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 10-01-2008, 04:35 AM
I have a straight carbide bit that I have had for several years and have cut numerous bolts etc. It has never met its match. I just cut through one side then split the nut.
Kevin
'79 Coupe
Old 10-01-2008, 05:04 AM
Dremel makes some small cut off wheels, if you don't have access to air tools. They work OK on bolts and nuts.
JR
Old 10-01-2008, 05:16 AM
David in VA's Avatar
I used a Dremel with a cut-off wheel on a couple of nuts which wouldn't budge. Sliced through them very easily.
'87 911 Coupe
'95 911 Coupe
'04 911 GT3
'98 Jeep Wrangler
Old 10-01-2008, 05:26 AM
JeffO's Avatar
I saw the carbide disk on their website and thought that looked real good. I think the cutoff wheel is also the next best thing.
1988 911 coupe
2008 VW R32
2004 530I
Old 10-01-2008, 05:30 AM
MBruns for President
JeremyD's Avatar
Cut off wheel and split the nuts - or if you are lazy - call your local muffler shop and find when their "down time" is - take your new hardware with you - have em cut off the old with a torch - and put on the new - Some places will do this for $20-$40. That makes it really easy.
Old 10-01-2008, 05:58 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Use a chisel, you will thank me.
Once the rust breaks it will come off easily. I went through 10 grinding wheels on the dremel until I used my chisel set.
Just take care not to chisel into the pipe housing.
'85 Carrera Targa
PCA/POC
Old 10-04-2008, 11:33 PM
burgermeister's Avatar
Oxyacetylene and a cutting tip will get those nuts off in about 15 seconds each.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 10-05-2008, 12:57 PM
rnln's Avatar
I did a search in yahoo for "Oxyacetylene" and found this:
and this
yohoo, I wish to have one to work on exhaust system
Fat butt 911, 1987
Old 10-05-2008, 01:16 PM
JeffO's Avatar
I used the 1 1/2 inch cutoff wheel. It cut thru the nut and the bolt in about 30 seconds. One of the best tool experiances I have ever had. I used the dremel at 30,000 rpm.
1988 911 coupe
2008 VW R32
2004 530I
Old 10-05-2008, 02:37 PM
rnln, those look much better than what I've got in the garage ...
Old 10-05-2008, 05:05 PM
