Old 60's Porsche Tech
captainlewis's Avatar
Question Carrera left bank tensioner feed line seal to tensioner?
I have identified a small leak at the left bank (1,2,3 side) cam tensioner oil feed line . I tightened this fitting which took about a 1/2 a turn. I thought this would compress the banjo fitting sealing rings. I cleaned off the area thoroughly ran the car for a few hundred miles and rechecked the area around the fitting and found it wet again, just a little seeping. After studying a manual I can see that there is a little O-ring on the tensioner itself sealing it as it goes through the timing chain cover. I was thinking of replacing the banjo fitting seals but suspect the O-ring is the problem, with 174,000 on the clock. I also believe to do that seal I must remove the timing chain cover. Any tricks or suggestions, thanks JL
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 03-04-2009, 07:10 AM
Tim L's Avatar
Sometimes the small steel tubing cracks at the fitting??
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 03-04-2009, 07:52 AM
Yes you do have to remove the cover, but it is not a big deal. I would replace that drilled bolt. My guess is it is about to break on you after you tightened it 1/2 a turn. At least get 2 spares, they are cheap. I always have a spare some where in my cabinet. I also have hundreds of the aluminum seal washers.
It will be a good project for a saturday morning. Start at 6AM, done by lunch.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-04-2009, 07:55 AM
what do you have to remove to get the cover off?, thanks for the help JL
Old 03-04-2009, 07:57 AM
Rrrockhound's Avatar
6 AM??!! Glad I don't live at your house.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 03-04-2009, 06:25 PM
Less brakes, more gas!
euro911sc's Avatar
6am is too early for bier...
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 03-04-2009, 07:36 PM
