Alter Ego Racing
ErVikingo's Avatar
Dim H4
Guys,
One of my H4's is dim (left side). Bulbs are fine. Time to check grounds or ?
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 10-07-2008, 06:03 AM
Ground or valtage issue. Check and clean the connections first then break out a meter and measure the voltage and resistance to ground at the bulb.
JR
Old 10-07-2008, 06:07 AM
Alter Ego Racing
ErVikingo's Avatar
Thanks JR. Any values in particular I'm looking for?
Old 10-07-2008, 06:47 AM
see if the wire colors are arranged the same on both plugs.
206 637 4071
Old 10-07-2008, 07:09 AM
scottb's Avatar
Assuming wiring is correct, my guess would be ground. I had a similar problem on a 72 240z, and replacing the ground wire fixed it.
1984 Targa
Old 10-07-2008, 09:45 AM
As close to zero ohms as possible for the ground and as close to battery voltage (as measured across the two terminals) as possible for the positive wire. When in doubt, you can measure the good side and compare.
JR
Old 10-07-2008, 06:49 PM
rgrimm's Avatar
Unless you're absolutely certain the wiring is correct, what John Walker's said. A friend was about to throw away the lights on his 930 until as a last effort he looked at how the three wires were connected. A PO had wired the plugs wrong. The lights appeared to work normally...but were dangerously dim.
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 10-07-2008, 08:21 PM
