Brake shields, on or off?
Do I need brake shields?
Is the cooling improved without them? I run a few DEs a year and the brakes are a bit marginal on faster tracks. Any downsides to leave them of the car?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
I haven't had the shields on my car in probably 10 or 12 years. No drawback to removing them as far as I can tell.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Non Compos Mentis
Most track cars remove them, most street cars keep them.
Less brakes, more gas!
Mine are off on the front and on in the rear... Its more dusty in the front...
-Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
PMB Performance
I believe the factory even recommends removing them in certain circumstances. If you have the factory manuals, check for the troubleshooting chart.
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
Schleprock
Ditching the shields is not a must. A few friends who are fast still have the shields on their cars ('79SC and '95 M3) and they don't have problems with brakes. It certainly doesn't hurt anything to get rid of them and it's not unsafe. Just don't go thinking it'll solve your soft brakes. You need to hone your braking skills to fix that.
Also is going to depend on what fluid and pads you are using. But I don't want to open that debate...............
Kevin L '86 Carrera "Larry" |
Well, I didn't think that it would solve any big problems. But since I am in the process of changing the front wheel bearings and brake disks I thought I could leave them of.
The brakes don't go soft (well I don't think, they soft to begin with, but thats another story), but I have a few rotors.
I took mine off. Less weight and more brake cooling, even if it's just a tiny bit, has to help- right?
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD |
