Key Stuck in ignition!
OK so my key is stuck in the ignition. What's the best course of action? It DOES NOT want to budge and I don't want to force it. Jiggling, turning is doing nothing to loosen it.
That said, nothing else is affected.
'82 911 SC
Old 03-08-2022, 09:19 AM
Senior Member
Superman's Avatar
Perhaps the steering lock is holding pressure. Try turning the steering wheel while removing the key.
Mocha 1978 911SC. "Coco"
Old 03-08-2022, 10:20 AM
Heck, I’m only 5 not 71!
targa80's Avatar
Have you tried turning or putting pressure left or right on the steering wheel and turning the key?
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 03-08-2022, 10:21 AM
Will try those things. Again, I don't want to force it and may need to employ a locksmith.
I've only recently acquired the car from the second owner. I know the ignition switch was replaced about 15 years ago by the previous owner and he had no issues with this key so I'm not sure why I'm having an issue now.
'82 911SC - Chiffon White
IG @thechiffonsc
Old 03-08-2022, 11:23 AM
I got mine loose with WD 40
Hugh Lindberg
1972 911
1970 Alfa Romeo 1300 GT Junior
Old 03-08-2022, 11:37 AM
Yea, mine locked up when I was pointed downhill and turned the wheel towards the curb. I had to turn the wheel to release pressure and turn the key at the same time to release it and start.
This stuff (Tri-Flow) has bought me a lot of extra life out of the assembly.
Tri-Flow General Purpose Lubricant
https://www.acehardware.com/departments/automotive-rv-and-marine/fluids-and-lubrication/lubricants/13754?store=18444&gclid=EAIaIQobChMI-bLxgaO39gIVyytMCh0fMAEuEAkYBiABEgIkcPD_BwE&gclsrc=aw.ds
Old 03-08-2022, 11:42 AM
Mine was sticking and I sprayed it with WD40 and it’s been fine ever since
Old 03-08-2022, 12:35 PM
