Originally Posted by safe View Post
I know the sender is different, 5 vs 10 bar.
But whats with the temperature sender? Is there really any difference?
I think the difference is the calibration of the temp gauge and sender. The 2.7 gauge is calibrated for the 2.7 sender and the 3.2 gauge is calibrated for the 3.2 sender.
I used the '77 2.7 temp gauge with the 3.2 sender and was getting extremely high temp readings. When I installed the 2.7 sender in the 3.2 engine the reading became normal.
Old 10-11-2008, 04:52 AM
cubby911T's Avatar
I actually encountered the exact opposite result. My '77 (numbered) oil temp gauge showed ridiculously high readings with the 74-76 sender. When I changed to the 77-89 sender (911-606-112-00) my readings normalized and I was able to confirm those readings by conducting a fairly simple test. Check out this thread for my testing details:
new 3.2 running hot.....maybe
Scott, is it possible that your gauge is actually from a 74-76 car? I'm pretty sure my '77 gauge is original. If you look at the earlier oil temp sender description in the Pelican catalog, it does say for years 74-76 only:
I can only guess that the '77 numbered gauge responds like the non-numbered gauges that came in subsequent years. At least, that's how it appears to me....
Matt M. -- Go Irish! 1990 964 C2 Targa
"Cheap tools and no experience has taken its toll" - J.W.
Ghosts of the Past: '77 911S Targa 3.2 Conversion, '89 Carrera Coupe, '99 Boxster, '70 911T Coupe ,'80 911SC Targa, '77.5 924
Old 10-11-2008, 07:49 AM
I would rather be driving
jpnovak's Avatar
Don, great work.
Old 10-11-2008, 11:13 AM
3.2 CAB's Avatar
Wow, it looks like a lot of trouble to change from a 915 to a G50. I didn't realize that it would have been that much work and fabrication needed.
+1 on the super work Don. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-11-2008, 12:53 PM
I dunno. I believe my numbered gauge is the stock '77 but who knows. I just know I ended up pulling the sender out of the 2.7 engine and installed it in the 3.2 engine to get correct temp readings.
Old 10-11-2008, 02:13 PM
