big brakes kit for pre brakes booster cars
i have a 76 911 that is going for the conversion of 2.7 to 3.2 and 915 to g50. the next obvious thing is brakes.
can/must i install a booster too or can i go only with bigger calipers n rotors from newer model or aftermarket kit?
911 TARGA 1976 - 3.2L, G50 SHORT BELL HOUSING.
Toyota Hilux 4x4 2000
VW tuareg 2009 3.6
HONDA SH350
Old 10-10-2008, 01:31 PM
Bill Verburg's Avatar
unless you want to do a lot of scrounging and fiddling, buy a kit
917 from Zuffenhaus
930 from Rennsport or VCI
GTP-L from Pelican
you can use a 23.8mm ATE m/c that is a bolt in replacement for you stock 19.8mm.
You can install a later boosted setup but it's a lot of work for not much reward.
Bill Verburg
Old 10-10-2008, 02:22 PM
