-   -   Itermittent Start/No Start on 3.2 Conversion Car.... Please help. (http://forums.pelicanparts.com/porsche-911-technical-forum/435310-itermittent-start-no-start-3-2-conversion-car-please-help.html)
crashr 10-13-2008 08:19 AM
I have a 87 3.2 Euro engine in my 1975 car which I can't get to start consistently. After we dropped the engine in the car the engine would start every time. Earlier this year the car was in at the body/paint shop and for the first time the car would turn over but appeared to have no spark. We went down to the shop and checked to make sure none of our wires in the trunk had come loose, it looked ok. We went to start the car up and it fired up. The car didn't exhibit this behavior again until two days ago after I got it out for my first drive in several years. The car ran fine. When I got home and turned it off a few minutes later I couldn't get the car to start. For the last few days the car doesn't appear to have any spark, but occasionaly it will fire up when we try it. When it starts up it runs perfect. You could turn the engine off after that and once again it won't start.
We have checked all our wiring from the conversion and it appears to be correct. The black wire at the coil has a constant 12 V however we get no spark. I checked to make sure there was 12 V at the DME relay pin on the security system (my car doesn't have one) and it appears to be there. I even took the DME relay out of a funcitoning 88 3.2 and tried it in my car and it still wouldn't start (so I ruled out the DME relay).
I am running out of ideas on what the issue is and how to isolate it. I am open to sugestions to what it could be.
ossiblue 10-13-2008 08:28 AM
Does the CDI box "whine?" Even if it does, it may be going south. Also, check the notorious "green wire" (do a search) from the CDI to the distributor.
JeremyD 10-13-2008 08:28 AM
What does the reference sensor look like? Was it installed correctly as in the correct distance from the flywheel?
crashr 10-13-2008 08:50 AM
I didn't think there was a CDI unit on the 3.2? I thought that came out with my 2.7. Am I wront here.
JeremyD, I will check the distance on the reference sensor. I guess I should probably check out to make sure it is sending the apropriate signal.
kach22i 10-13-2008 09:44 AM
Have you checked all of your fuses in both the front and back of the car? Sometimes they look fine, but take them out and they fall apart in your hand.
I may have a similar problem, can't tell yet:
No start last night - starts up this morning
http://forums.pelicanparts.com/porsche-911-technical-forum/435152-no-start-last-night-starts-up-morning.html
sbrown.nw 10-13-2008 10:29 AM
From what I can tell from your description, my car reproduced similar or the same behavior, espeically with hot starts (fuel pump would buzz, plenty of juice and car would not turn over some of the times, then she would sit overnight and start fine). Tried 3 new (rebuilt) starters and it did not fix the issue. Installed the Starter Relay Kit Starter Relay Kit and now she fires up every time without problem (she is a 72T with an 85 Euro 915 and 3.2). Our host seems to be out of stock for this item but web searches should find you one for purchase...
Also, at the same time, I had my mechanic remove a "Mickey Mouse" detuning box on the Euro 3.2 from the wiring harness, restored the wiring harness to factory and put in a Steve Wong Euro chip and she starts the first time without stalls hot or cold and idles much better.
:) Scott
Formerly Steve Wilkinson 10-13-2008 11:07 AM
The green signal wire to the distributor is an item that most serious maintainers routinely replace every so often, it's that prone to failure.
crashr 10-13-2008 11:56 AM
Hi Steve,
I thought the only wire going to the distributor is the center coil wire which feeds the spark plug wires. Do you mean the green wire on the coil which goes back to the DME?
Formerly Steve Wilkinson 10-13-2008 12:00 PM
Well, my SC has carbs and no DME, so I don't know where it goes on yours. It's the short green wire that has a special connector on it and goes to a small plug on the back (toward the front of the car) of the distributor body, not the cap. It's actually a fairly delicate coax that often fails. Car will crank, everything else works, but no start.
3.2 CAB 10-13-2008 12:33 PM
It appears that some are getting the wrong impression about the type of system that you have, and the symptoms it has.
You state it is NOW a DME controlled 3.2 engine.
It did crank and run.
Now it does not start, but does turn over.
It will sometime start, other times not.
I don't see mention of a no cranking condition.
I would check the crank reference sensors and the wiring connectors to them.
The speed and reference sensors are hard to get a true idea testing, without a scope, in order to check the sine wave.
From what you have stated, I am in agreement about the cause could be the reference sensors. In order to check the distance, the holder would have to be removed, and the sensors removed, then reinstalled, using a 0.08mm washer temp. glued to the bottom of the correct sensor, and the the holder bracket installed, and adjusted and tightened. the the sensor with the washer removed, to have the washer removed, the reinstalled. The other sensor, will be adjusted correctly, because the sensor the has the washer, is actually adjusting the depth of the holder, this will allow the sensors to be held at the proper setting. Good luck!! Tony.
crashr 10-13-2008 07:08 PM
3.2 Cab you are correct it is NOW a DME controlled 3.2 engine. Also you have restated my symptons correctly.
I checked the reference sensor resistance and between pin 1 and pin 2 it was 1024ohms; which is within spec based off of Bently.
I also checked the resistance between 2/3 and 1/3 however they showed up as Infinite and not 100kohm. I know 100kohm is a high resistance but it is still different than an infinite resistance(open circuit). Does this mean that my reference sensor is bad?
I am picking up some probes for my osciliscope this week and will take a look at the AC signal. In the meantime can someone comment on the DC infinite resistance I am seeing?
Also I tried to use the 5mm Allen key to get the sensors off, but the bolts seem very coroded, any suggest on how to best get them out without stripping or destroying them in the process?
Just to add an extra kick in the pants, my car started up tonight, however after we shut it off and tried to turn it on a minute later it wouldnt start again. When it did start however it seemed to have to crank over for a few seconds as if it was still looking for that reference pin. Thoughts?
crashr 10-13-2008 08:57 PM
I was just reading through the archives. Although I don't think it is related but I thought I might mention that I believe my fuel pump may be wired to always be on when the key is in the on position. From what I have read it should wait to turn on until the engine is cranking over. Would this effect me in any way? If left for to long in the on position will the engine flood? I just thought it was odd that I can get it to start when I leave it for a few hours.
TT Oversteer 10-13-2008 11:23 PM
I have a '89 3.2 in a '77 911S. My fuel pump is on all the time when the key is on. I've never had any flooding or starting problems.
crashr 10-14-2008 08:44 AM
Ok good to know about the fuel pump.
Back to my question on the sensor. Does testing the resistance mean that the impulse sensor is working properly or can you get a proper resistance measurement from it and it still be malfunctioning? It appears that the car will start up when cold, but once warm I get no spark.
3.2 CAB 10-14-2008 12:35 PM
From old post of mine
Hi Nick, don't replace the TDC sensor, that is only a diagnostic sensor, it has nothing to do with the engine running, it is test device only. You can try to test the, Ref/Speed sensors, but usually they will test ok with a meter, but the only real way to test is with a scope and check the sine. When it does die, have you checked to see if you have spark or not, if you do and it does not want to start, you might have a fuel problem, maybe a stopped up filter or strainer, or even a pump starting to seize up. Could also be the CHT sensor, even though you have a fairly new one, test it, it does not affect starting persay, it controls fuel, not spark, but it will make it run like crap. Another thing to check is the large vacuum line connection behind the heater blower, the one that tee's off from the metal pipe, it also has the little vacuum line for your cruise, on the y fitting, and the big vacuum hose for your brake booster, a lot of times these hoses at the fittings will crack, and cause a large enough vacuum leak and really screw up the way the engine runs.
As Ron said, I had a ref/speed sensor problem, if the outside temp was below about 70 degrees outside, the car would not start, no spark condition, checked everything, popped in a new DME relay, nothing... this went on for a few days, but after the car sat in the closed up garage all day and it got warm in there, it would fire right up, wouldn't turn over twice and it would start. That went for a couple of days, everytime I would try to start it after it sat getting warm in the garage all day, it would start right up, so then I decided to warm up the components, using a blow dryer, to see if it made a difference, first I warmed the DME unit, then the relay, no spark still, then the ref sensors wire connections, no spark still, rolled under the car and warmed the ref/speed sensors for about 10 seconds, rolled out from under, hit the key, it fired right up, ran perfect. Could turn it off and try it again, and it would start right up again and again..... So I left it till the next morning, was about 50 degrees outside and in the garage, tried starting it, would not start, NO SPARK, rolled under it with the blow dryer, heated the ref/speed sensors a little, rolled out, tried to start it, fired right up!!!! Went in and ordered 2 ref/speed sensors!! Replaced them, have not had a problem with the DME system since. I tried to find out what it could be that the temp would affect, before I discovered what was wrong with mine, but no one had an answer, kept being told nothing could be temp related to this problem. A Porsche tech helped me a lot, but he is over a hundred miles from me, but I would go there and he would help me trace the DME circuits and everything else that would control the running of these engines. He even had a colored DME circuit wiring diagram that was huge, like 2'x4' you could trace everything. I learned a lot from him about the DME system. Hope I was able to give you some ideas. Good luck.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
crashr 10-14-2008 12:47 PM
Thanks that does help. I am going to test the sensors with a scope and will report back on my findings.
crashr 10-19-2008 07:15 AM
So my car started all week when cold. You can start it, turn it off, start it again no problem.
I had to bring my car to the body shop to have the fender lips cut back. Its about a 30 min drive. Car ran great. As soon as I got to the shop I turned off the car and as expected the car would just turn over and over with no spark.
I did find this thread ( http://forums.pelicanparts.com/porsche-911-technical-forum/339441-motronic-control-unit-problem.html?referrerid=11933 ) from a member who seemed to experience the exact same problem. I emailed him to ask if he resolved the issue and he told me that once he had the flywheel sensors replaced the problem disappeared.
The only difference between the problem you had 3.2cab vs my issue and tastytel's issue is that our cars would start fine when cold but not once warm. I believe your issue was the opposite in regard to ambient outside temperatue.
3.2cab as you mentioned earlier it does seem that when these parts fail or begin to fail they may be affected by temperature. Could it be the position to the pin somehow changes ever so slightly across temp or just the sensor itself?
Anyway, I have put in an order for my impulse sensor and will update everyone with the results once I install it.
CliffBrown 10-19-2008 12:02 PM
Dennis
There are a lot of threads on the Forum regarding problems with bad solder joints in the Motronic DME.
crashr 10-19-2008 01:09 PM
Hi Cliff,
I have seen a bunch of these threads as well. My thought is if the Impulse sensor replacement does not fix the issue then the DME box must be the culprit and I will open it up and take a look at the solder joints.
crashr 10-25-2008 09:55 AM
Ok I'm really getting frustrated now. The car was cold and I started it up ran great. Took off the sensor cable for the reference sensor and saw my 2V peak to peak voltage. So then we let the car warm up for 10 minutes. Turn the car off and as usual it just turns over. At that point I checked the Ref sensor at the engine again and I still see the 2V peak to peak voltage as it is cranking over. I thought this would eliminate the reference sensor from being defective.
Next I moved to the DME. I swapped out my DME with a known working DME and it still wouldn't start in my car. Put my DME in the other car and the other car fired right up. This should rule out the DME.
I have done the same swap with the DME relay. Same result.
I started checking ground locations and them seem to read close to 0.5ohms. One caveat is that my engine ground location thread (on fuel air input area) is somewhat stripped and the bolt won't tighen right down however we are getting .4ohms resistance from that bolt to the body.
I am running out of ideas. Could it be the alarm? I don't have one as this was a conversion car. Is there any way to test if this is what is causing the problem? Also any other suggestions on what I should be looking for?
crashr 10-25-2008 10:33 AM
Hi Cliff,
I have only ever tried to swap the DME and DME relay when the car will not start. I take the DME and DME relay independantly and swap them out. The result for both tests is that my car still will not start however the other car will start fine. Does this answer your question? I just checked pin 86 at the relay and I have 12 V there so my understandin is that the alarm should be working fine.
crashr 10-25-2008 06:01 PM
Although, not the cause I was going back over my 3.2 conversion wires. I noticed that I had taped up the yellow wire in the trunk (pin 4 on DME) that from the diagrams is supposed to go to the ignition switch. I believe this was suppose to be connected to a fuse that is only on during cranking; however I can't seem to find any fuse that fits that condition.
Keep in mind that the car has run before without this hooked up but I wasn't sure if I tried to wire this up if it may help me better diagnose my symptoms. I am starting to wonder if I even have fuel now when I have the no spark condition.
Also as mentioned earlier in the thread I believe my fuel pump has been wired differently so that it is always on once the key is turned. This was also suppose to go to a wire that was taped up (black wire in trunk area). Not sure if any of this will help me in getting to the fundamental problem or if I am just convoluting the problem.
scarceller 10-27-2008 07:24 AM
Pin #4 in the 84-89 cars is used and is very important! You are correct that pin 4 needs 12v while cranking. Internally in the DME when pin #4 sees the 12v it then grounds pin #20 which in turn grounds the DME pin 85b. This activates the fuel pump relay. This is required to run/start the fuel pump while you are cranking. In the stock configuration if pin #4 does not see 12V while cranking the fuel pump will not run! You can test this circuit by simply turning the key to 'RUN' then apply 12v to pin #4 and you will hear the fuel pump run.
Now the question I have is why could you start the car without pin #4 wired? When you wired this DME into the 75 car you must be running the pump some other way. If this is the case then maybe you don't need pin #4 wired. But this also means you would not be using the Fuel Pump relay within the DME.
As for why the car starts sometimes and not others I think this is something else. When it does not start I assume the motor still cranks? Do you smell fuel while it does not start? I ask because if the injectors are running you quickly will know it as you start to smell raw fuel.
Another quick check is to test for 5v on the AirFlowMeter at the Blue/GreenStripe wire at the AFM Harness. Seeing 5v here tells you the DME is alive and that the DME relay is working. Do this with key in 'RUN'
Once we know the answer to the above tests we can decide what to test next.
crashr 11-01-2008 01:44 PM
Hi Guys,
So I did several things today.
I wired up pin 4 from the harness to a yellow wire coming from my key.
I also wired my fuel pump to the DME Relay wire so it only comes on, on start.
After doing this the car as usual started when cold. I drove the car around the block 2 or 3 times parked it, and once again it wouldn't start.
I changed out the reference sensor with a new one but the car would still not start.
I then followed Lorenfb's steps in another thread. Here were the steps he suggested and my results:
Tests:
1. Check spark at coil wire (Result: No spark whatsoever)
2. Use a $3 injector light to check for injector pulse (Result: I used an osciloscope and saw no signal at all, an no smell of fuel)
3. Check the main power pins; 1, 18, 35 and injector power 14, 15 (Result: Had 11.4V at each of the pins)
4. Check for grounds pins; 5, 16, 17 (Result: All grounds showed 0.6ohm)
5. Check fuel pressure (35-40 psi) (Result: Didn't know how to do this)
6. Check pickup sensors; 8/27 (2.0 VAC), 25/26 (.10 VAC) (Result: A voltmeter didn't show anything on either however when I hooked up the Oscilloscope the speed sensor showed a signwave with a voltage 8V peak to peak (why is this so high?) and the ref sensor showed about .4V peak to peak)
7. Check temp sensor; ~ 300 ohms hot, > 1500 ohms cold (Result: where am I checking this, also i put a new temp guage sensor in however it doesn't seem to be working)
Something else to add is that I still don't have the oil cooler on the car, however it is quite cold here now, and I have heard others do this without the car getting even close to temperature. I wouldn't think that after 10 min of running that the engine could even get to full temperature.
So I am looking for suggestions on where to go from here.
scarceller 11-01-2008 02:28 PM
No Spark and No injector pulses usually means something is not working with the Ref and Speed sensor. 8V pp is really high for one of those, double check them when cold and then again at no start.
crashr 11-01-2008 02:44 PM
Just retested and it looks like I made a mistake. It is 4V peak to peak on the idle. As mentioned I replaced the reference sensor.
scarceller 11-01-2008 02:49 PM
Did you fix the ground screw on cyl #1 intake runner? + check/clean the ground strap in front of trany.
crashr 11-01-2008 02:56 PM
I took the tranny ground off and soaked in vinegar and scrubbed it with vinegar. It now looks new. I then moved the gronds on the intake that was stripped over to intake 3 where the ref sensor and idle sensor mount to the intakes.
What voltage do you need at the battery for proper operation of the DME?
scarceller 11-01-2008 04:28 PM
The battery should have 11.8 or more, if you question the battery have it tested
crashr 11-01-2008 04:55 PM
Could the battery cause this type of behavior?
Could bad solder joints in the DME cause this type of behavior?
stlrj 11-01-2008 05:23 PM
And I assume you made the critical adjustment of the sensor distance to the flywheel.
crashr 11-01-2008 10:24 PM
I never moved the bolt for the mounting bracket, however I did try and squeeze a feeler guage in there and it appeared to be between 0.82mm and 0.88mm
ischmitz 11-01-2008 10:45 PM
When you have the no-start situation check if the DME is actually running. Simply switch the key to ON and check if the ICV vibrates. It's the silver can on the intake.
This is a very quick check to confirm that the DME gets power and actually runs.
ischmitz 11-01-2008 10:47 PM
I was under the impression you swapped your DME into another car and it ran. Why are you still questioning the DME being faulty?
Your battery voltage is too low. You want at least 12.4 Volts. If you have 11.4 volts and start to crank I bet the voltage will drop below 10V and that will cause issues.
scarceller 11-02-2008 05:54 AM
I agree, any battery reading less than 11.8V should be questioned. Place a charger on the battery overnight. Also have the battery load tested most Auto Parts stores do it for free.
scarceller 11-02-2008 05:56 AM
As for the ref and speed sensors, you have a scope so simply measure peak to peak volatge while cranking. The motronic ttest manual states 2.5v or greater your good to go. If the voltage is lower then adjust the gap, otherwise leave them alone.
But test them again when the failure occurs.
scarceller 11-02-2008 06:09 AM
Also, when failure occurs measure for 5v at the AFM while cranking be sure the 5v is seen at the AFM while cranking. If it is the DME power is most likely OK.
crashr 11-02-2008 07:05 AM
Ischmitz,
I checked the DME by swapping out my DME with one from a 1988 3.2 NA car. In fact I didn't really want to do this because the part numbers were different for the DME. I later realized that two pins are swapped between the years of 87 and 88. My DME DID work in the other car however I didn't want to harm the other car by trying to drive around and letting it warm up so I can't be certain thats what the problem was.
I have checked what I believe is the AFM (4 pin plug), when the key is at the on position I get 4.6-4.8V on the blue/green wire, which I believe I read somewhere was the test? I don't believe I checked it while I was cranking.
ischmitz 11-02-2008 07:38 AM
The voltage on the AFM connector is from an internal voltage regulator. The fact that it is present tells you the DME sees more than 6 or 7 volts on its supply pins while not cranking. Nothing else. The same is true when you feel the ICV vibrating: You know that the internal CPU is running and that the idle control output stages are fine.
However, once you crank your car a weak battery can quickly let its output drop below 8 volts. This is why Sal is recommending a load test at an auto parts store. Charge it overnight is also a very good idea in case it simply isnt't fully charged. The low battery voltage will first fail to open the injectors. This is why you need to know your system voltage (battery) while cranking.
BTW: Different DME's can be swapped even if part numbers don't match for the 3.2. The only thing you might notice is that a newer DME results in hunting idle on an older car. But that is an adjustment issue of the AFM air bypass and won't hurt anything. You can drive the test car with your DME and let it warm up. It won't hurt a thing in the new car. IF your DME was going to hurt the test car it would have happened instantly (burned injectors or ICV in case a driver stage in yours is short). The vert fact that the test car started tells you that wasn't the case.
I recommend letting your DME fully warm up in the test car to exclude any doubt that is has an issue.
Ingo
crashr 11-02-2008 08:24 AM
Just searching the wiring schematics so I properly understand all sensor inputs. Can someone comment on what the microswitch does white/green (pin 2) from DME. I can't find anywhere in the Bently manual where this is discussed. Also is there anyway that a faulty NTC will make the engine thinking it is overheating and cause a no start. From much of what I have read the answer is no, but I figure I would ask.
