Another Motormeister special...
Engine failed at 1000 miles after rebuild?? Looks like a clean chassis though...
Bandwidth AbUser
Hey MJ, this was brought up a few days ago. What a pity about the engine...
Jim R. |
Sorry I missed the thread..I'm out of it..braindead!!
Speaking of the infamous MM has anyone bought their reground cams? Are they rehardened?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Just don't do it!
You'd be giving money to someone who screws porsche owners for a living. Solidarity man. Friends don't let friends buy from MM.
Mike Searching for a new ride '04 VW GTI 1.8T RIP ![]() '76 911S 3.0 RIP ![]() http://www.pelicanparts.com/gallery/BanjoMike |
Non Compos Mentis
If I had a tired 911 engine laying around, it would be interesting to have MM rebuild it, just to tear it down and see what they did.
true true.... $400 cams vs 800 cams is tempting though..
someone slap me for even consitering it.
Hilbilly Deluxe
www.elgincams.com Tom |
Thanks tom that'll help alot.
BTW are they rehardened back to factory specs?
Irrationally exuberant
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
MM claims an IRAN concept, which they borrowed from the aviation business- inspect and repair as necessary. The problem is that some stuff is LIFE LIMITED- like a cam sprocket, these things wear out over time, why wouldn't you replace them? Ahh, but that drives up the cost of the rebuild, and that's not consistent with their position in the market.
It's like buying cheap computer equipment-- you take a chance that it works, and if it burns up the price is so low you buy another one. Except that the numbers don't work in the MM context, which is why everybody steers clear.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Tim,
Elgin regrinds for $280!! I don't know who MM uses for their regrinds or if they do it in house. If its the latter, STAY AWAY. http://www.elgincams.com/main.html I forgot who I talked to at Elgin, but he was quite knowledgeable. It wasn't Dima though. If you talk to him, even better.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
Warren Hall Student
I bought a pair of MM reground cams from a fellow board member. I think I gave him $20. I sent them to Elgin to check the specs. After inspection they found they're way to the trash can.
For what it's worth. I don't think MM rebuilt that motor. If you re-read the ad it says that MM offered technical help. It sounds like the PO did his own rebuild.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ Last edited by Bobboloo; 06-24-2003 at 01:10 PM.. |
Can anyone please comment , if MM is that bad, how can they stay in business? Their company looks pretty big from thee web site. MM must have done something right to stay in the business. I am 15 min. away from MM. I might do business with them someday.
Caliber 1987 911 Cabriolet |
I've never heard of the "IRAN" concept and I've been spinning wrenches in General as well as Commercial Aviation for going on 20 years now. I can ASSURE you that Life Limited Parts (LLP's) as well as most other parts in an aircraft are tracked and their condition accounted for even during a Light Maintenance Visit (LMV). If Motor Meister was as heavily policed by an entity such as the FAA, they would cease to exist with fines and jailtime abounding for negligence and fraud.
1995 C2 w/Tiptronic, Stongard, HID's |
-Chris
Like lumber from Home Depot, if you have the time you can measure and send back parts to MM until you get some in spec. BTDT with a crank.
-Chris
Yes Chris, it is truly amazing --- "You can lead a horse to water ---"
IRAN is not an aviation concept, it's a _military_-aviation concept. Quite common there.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
