big tire v big rim?
What is going to be faster?
Running the largest tie that is recommended for a given rim size? Or, the largest recommended rim for a given tire size. For example. For a R888 225/50 the recommended rim size is 6-8". A 245/45 recomends a 7.5-9"rim. I have 8" rims. So what is faster assuming a proper rear suspension set up. The 225 or 245 if the only rim choice is the 8"? |
N-Gruppe doesn't exist
two tires different sizes spinning at the same RPM????? the larger diameter tire would be going faster.
but your engine rpm will be different. and your speedo will be off unless you corect for tire ratio and gearing.
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods |
In the real world that most of us live in compromises need to be made, but if I was going to go to the trouble of running R rubber I would want 225/ on 8s and 245/ on 9s it's been a while since I used those sizes but there is/was a timeable difference lately i've come to the conclusion that there is no advantage to a 275/ on 9.5 over 265/ on the same wheel.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 10-17-2008 at 05:49 AM.. |
Bill, was hopping you were watching.
So for a Carrera with mild suspension and an 8" rear rim requirement, are you saying a 225 is a better choice than the 245 using a tire like the R888? Is the 245 being bigger and approved for that size rim going to be faster given the righ settings? Thx in advance. |
PS, who makes a 265/17 tire?
