SCWDP911's Avatar
Winter projects 2008-2009?
Well, since no one has started it yet, thought I would. What are your projects for this "offseason".
Shane
- 1984 928S
Old 10-17-2008, 05:57 PM
krd krd is offline
krd's Avatar
to replace all of the suspension bushings, cv joints, paint my fender wells, upgrade brake lines, in my 1988 "ce" cabriolet
1988 porsche 911 "CE" cabriolet
Old 10-17-2008, 06:01 PM
Oh Haha's Avatar
Well, nothing broke this season so I may not "need" to do anything.
I would like to replace the carpet with new and get a new power amp for the stereo.
Pacific Blue
Wayne
Old 10-17-2008, 06:05 PM
Happiest when Tinkering
gsmith660's Avatar
Oh well lots to do and don't know where to start!
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 10-17-2008, 06:23 PM
old man neri's Avatar
Shocks/strut inserts
Turbo Tie roads.
Reposition/redrill aftermarket driving lights
Reseal brake calipers.
Bleed clutch/brakes
Figure out what else might be wrong and spend money fixing I guess.
Old 10-17-2008, 06:31 PM
pookie's Avatar
Before winter
Replace turn signal switch
Put in H5's
Wire up Surco relay for headlights
Redo heater hoses so I can still drive when it gets cold
For the winter
Swap to thicker torsion bars in order to run larger wheels
Put on 16x7 wheels that have been in the gararge over a year
By the way Shane I notice you don't have a list. if you want to help I'm sure I can find something for you to do...
1976 911 S Targa 3.2
Old 10-17-2008, 06:34 PM
SCWDP911's Avatar
Originally Posted by pookie View Post
Before winter
Put in H5's
For the winter
By the way Shane if you want to help I'm sure I can find something for you to do...
Yeah, we need to start a MTWS... mid tn wrenching society
Ryan, David and I are going to be doing a valve adjust (my 1st) on Sat the 25th.
Shane
- 1984 928S
Old 10-17-2008, 06:38 PM
Model Citizen
herr_oberst's Avatar
Replace some fuel lines, new intake manifold gaskets, give the brakes a hard look, maybe new discs/hoses/rebuild the calipers if I see a "need", (they work fine, now, but I noticed a ridge on one of the fronts this summer, so in my mind it has now become a wafer-thin recipe for disaster) some dynamat under the seats and in the doors, get a golf ball dent removed fom the hood. Maybe do a REALLY NICE job buffing out the paint
I'd like to find an alloy wheel for the space saver spare. Cookie cutter? Phone dial?
Old 10-17-2008, 07:35 PM
One year of ownership and have a list for my 87 Carrera....
-Front and rear wheel bearings
-Sending out all my gauges to Bigmark to have Glass lenses put on, fix the clock and precautionary service to the speedo.
-Center cosole recovered
Take out seats and wash/clean the interior.
fix 2 valve adjust screw/nut. threading is messed up and a PITA to adjust
--install new O2 sensor
-Install OEM radio
- Repair replace power lock switch on console
-Repair replace seat switches, thank god only 2 on Drivers side, pass side is manual.
-Fix AC compressor leak....
-Clean all electrical grounds and connections
-Make more Porsche friends, need help with car stuff willing to pay, wife is not a car person and won't lend a hand, my almost 4 year old boy is the best I've got for help and guidance. I must be the only one with an older 911 in my town
Old 10-17-2008, 07:55 PM
efhughes3's Avatar
What's offseason?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-17-2008, 08:06 PM
Paul K's Avatar
Originally Posted by efhughes3 View Post
What's offseason?
That would be when there's 4 feet of snow outside! Do a search for snow, you'll soon get the picture!
My plan:
Have Dan Petchel rebuild my spare Targa top and send me a new front seal.
Remove the headlights and get rid of the 'fog'
Install a new FTP switch.
Trace some electrical gremlins (light under the dash doesn't come on no matter what, engine bay light doesn't work)
Maybe a SW chip.
Cheers,
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 10-17-2008, 08:44 PM
Recreational User
porschenut's Avatar
Complete suspension refresh with new Bilsteins, turbo tie rods, and new rubber bushings everywhere.
Complete new interior, back to stock.
Repaint the trunk lid, front bumper and front quarters.
New windshield, new wheels, new tires.
Old 10-17-2008, 09:15 PM
fritzgator's Avatar
Just cooling off enough that i don't break a sweat, THINKING, about turning a wrench.
Pull oil lines & try the "torch& comp air" approach. if that don't work ER finned lines.
New oil tank to cooler S hose.
Adjust valves while empty. probably backside method.
Replace last 2 old A/C hoses.
Rear wh.bearings.
Fresh 201 and Brad Penn 20/50
H4's
Gator
99 996 c4
Jeff Alton's Avatar
going from my 3.4 to either 3.4 turbo or 3.7NA....
Cheers
www.turn3autosport.com
Old 10-17-2008, 09:40 PM
SteveinTO's Avatar
"What's off season? "
Winter, the 24 hours of rain we could possibly get in February. Temps dip into the 50's at night. Car on blocks. Battery tender. Oil change before & after. Mothballs. Rat traps. Stabil. Pressurized whole car bag.
Winter engine rebuilds are a bi**h here.
Then spring.
Old 10-17-2008, 10:07 PM
midnight911's Avatar
3.6 conversion
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 10-18-2008, 01:58 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Two weeks left before the driving season's end. Ok....the list...targa front seal to replace...targa top skin to replace...doors panels to open due to some weird sound coming out from there...fuel filter...transmission ground strap is tired....And I have to remove the rear light housing due to some corrosion to clean...About it.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 10-18-2008, 03:45 AM
efhughes3's Avatar
OK, no more winter jokes:
My big one is getting my new forged 17" Fuchs repros from Mr. Alton (quite soon!!) and getting my new Advan A048's mounted....and then driving! Then she gets a shock revalve and raised spindles with a little massaging for a bit more camber.
I should drop the engine and fix my cam tower-head oil drip, but that doesn't sound like fun.
Ed Hughes
2015 981 Cayman GTS
Old 10-18-2008, 06:56 AM
I now have 5 cars and can't get enough energy to work much on the 89 911 - most of the time/money/energy spent on keeping the BMW's running for the wife and sons. If I made a list, it would be so long that I wouldn't do any of it. I'm hoping for the day when the sons will have jobs and get their own cars fixed. Then what will happen... I'll be doing the fixing for them after hearing what someone wants to charge.. so maybe no escape. Sorry if OT.
Old 10-18-2008, 08:56 AM
Paul K's Avatar
What size 'real' rim will fit in the space under the hood?
I might do that myself.
'83 SC Coupe SOLD
Old 10-18-2008, 09:16 AM
