Check out the 76 Targa I bought yesterday
Hi, so I bought it... I could not resist.
Thanks to all the advise here: Plnning to buy 76 Targa. What to check
The transmision is nicer then the one of my my 86. It shift really great!
What do think about the engine. It looks updated to me... The number is *6460868* . That is 2.7, right?
Any thoughts?
Thanks!
Old 10-18-2008, 06:25 PM
Is this steering wheel authentic?
Old 10-18-2008, 06:27 PM
Here is the car...
Old 10-18-2008, 06:29 PM
crustychief's Avatar
Nice! looks like it has the updated tensioners.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 10-18-2008, 07:49 PM
the the is offline
Definitely has Carrera tensioners. The smog pump and EGR tubing has all been removed and plugged up. Looks like it has had some engine work, at least the top end, the cylinders are very clean and it looks like it has relatively new one piece oil return tubes on it (the only way to get one piece tubes on is to remove the heads). Steering wheel is an aftermarket, non-original Momo Monte Carlo. Looks like it has SSI heat exchangers, nice!
Old 10-18-2008, 08:35 PM
f3nr15's Avatar
Yes.
Here's an old post from Grady that is quite useful:
Originally Posted by Grady Clay View Post
Your 7=digit ’75 engine number should have the form:
*6X5xxxx*
where:
6 = Engine design, 6-cylinder engine
X = numbers 1-7 (see list below)
5 = Model year 1975
xxxx = Sequential serial number usually starting with 0001. Exceptions: Starting with 9001 = engine for Sportomatic.
X = 1, 911, Type 911/41, (or Type 911/46 for Sportomatic)
X = 3, 911S, Type 911/42, (or Type 911/47 for Sportomatic)
X = 4, 911S/Carrera USA, Type 911/43, (or Type 911/48 for Sportomatic)
X = 5, 911S/Carrera California, Type 911/44, (or Type 911/49 for Sportomatic)
X = 6, Carrera 2.7 (MFI), Type 911/83
X = 7, Turbo 3.0, Type 930/50
Best,
Grady
Regards,
Peter
1992 928 GTS
1993 964 Carrera 2 Coupé
Old 10-18-2008, 11:04 PM
SCWDP911's Avatar
Man, LOVE that color! Nice find!
Shane
- 1984 928S
Old 10-19-2008, 08:54 AM
The best wast the price: 6500 ))
Old 10-19-2008, 05:31 PM
Poor-sche Lover's Avatar
The deals are out there, if you're willing to look. I'm about to make one of my own. The light's playing tricks on me. What color is that?
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 10-19-2008, 06:13 PM
It is hunter green.
Old 10-19-2008, 06:23 PM
holtjv's Avatar
Great color. Did middies have the antenna on the driver's side?
Warren Hall (Early S Man), 1950 - 2008
2006 Tri D675 Scorched Yellow
2006 Ducati Sport Classic mono SOLD
1979 SCWDP #0020 Talbot Yellow SOLD
Old 10-19-2008, 06:29 PM
I'm pretty sure it's manual antennas on the driver's side, power antennas on the passenger side.
Alan
Old 10-19-2008, 06:31 PM
Mine is manual. Is this gooor bad?
It not moving
Old 10-19-2008, 06:53 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Ho man...who would resist to this...The color is superb.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 10-20-2008, 04:24 AM
Greetings,
Congratulations, on the very nice ride. I have a question for this forum, if I may. I have a 75 911S with a 78 3.0 motor and am interested in removing the smog pump and EGR tubing and plugging it up. Question: What advantages would I see? Thank you all for any help you can provide.
Old 10-20-2008, 05:57 AM
Work in Progress
Rich76_911s's Avatar
Originally Posted by brucechas View Post
Greetings,
I believe the advantage you will see is cooler operating temperatures on the engine, which in turn will extend the life of the engine. Not too much performance gain as far as I know. Others will know more than me though.
Congratulations again on the great car Boris.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 10-20-2008, 06:08 AM
Another question: I have 16 inch wheels on the car and they seam too big. I think it needs 15 inch wheels. Correct?
Are these hard to find?
Old 10-20-2008, 06:23 PM
19 years and 17k posts...
azasadny's Avatar
Very nice!!! Congratulations!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-20-2008, 06:31 PM
It not moving
I like the manual for originality.
1980 911 SC Targa
Old 10-20-2008, 06:32 PM
My paint is cracking or bubbling at a couple of spots... Do you think it has been repainted poorly at some point or could the original paint look like this after 32 years?
Also, does anyone know what the original radio was in 76?
Thanks!
Old 10-21-2008, 07:12 AM
