CIS picture of backside on test bench
Can someone direct me to a picture i stumbled upon that shows the entire CIS system from the back side sitting on a work bench i think?
Hope this helps. These are all lambda systems.
82 911SC Targa (05 Boxster S ) gone, but not forgotten 87 Suzuki GSXR-1100 1953 MG TD Mk II |
nice pics
I am looking for the brake vacuum bost hose , should be 3/4" od ive been told.
also, what are those bright green plastic rectangles, just curious? Nice pics ty |
Isn't that on the firewall, by the cruise control servo?
Alan Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again Present: '00 Boxster S "Happiness is not around the next corner......happiness IS the next corner." |
brake vacuum hose
Ive been told its along the firewall and then down on the left side, but i cant see where it connects to a vacuum source
Plug wire goes from one turquoise plug to the other. Last edited by tcar; 10-22-2008 at 09:15 AM.. |
no, the one on the left on the air flow meter (AFM), goes to the switch that cuts off the fuel pump when the key is on and the engine is not running. the other one is the cold start valve
Tony Tony |
Vacuum line to brake booster......
![]() Tony |
boy911sc thank you
How do you get such good pics, thats exactly what i needed.
I replace the warm up regulator vacuum hose, some improvement, but still backfires. thursday the red and blue distributor vacuum get replaced and im going to recheck the fuel pressure. after that im going to trace the brake boost vacuum line. Its getting cold in northern ohio, running out of time before it all gets packed away in the barn. |
See the link in my sig if anyone needs a bunch of higher resolution CIS pics.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Cigars and 911's -- Smile
MCA, thanks for the download of CIS pics, very nice.
Tom
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
