CIS picture of backside on test bench
Can someone direct me to a picture i stumbled upon that shows the entire CIS system from the back side sitting on a work bench i think?
Old 10-22-2008, 06:27 AM
SC-targa's Avatar
Hope this helps. These are all lambda systems.
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 10-22-2008, 06:43 AM
nice pics
I am looking for the brake vacuum bost hose , should be 3/4" od ive been told.
also, what are those bright green plastic rectangles, just curious?
Nice pics ty
Old 10-22-2008, 09:01 AM
Poor-sche Lover's Avatar
Isn't that on the firewall, by the cruise control servo?
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 10-22-2008, 09:06 AM
brake vacuum hose
Ive been told its along the firewall and then down on the left side, but i cant see where it connects to a vacuum source
Old 10-22-2008, 09:08 AM
Frequency valve. In the very top pic, you can see the bottom end plugged in. You can't see the top end as the rubber bellows is moved out of place.
Plug wire goes from one turquoise plug to the other.
Old 10-22-2008, 09:13 AM
T77911S's Avatar
no, the one on the left on the air flow meter (AFM), goes to the switch that cuts off the fuel pump when the key is on and the engine is not running. the other one is the cold start valve
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-22-2008, 09:58 AM
Nice pics ty
The one on the top is for the air sensor plate switch and the other is for the cold start valve. BTW, the brake vaccum source is located at the air box driverside and it goes down to the bottom side of the firewall. Search for John Walker's post about vacuum leak and has a picture of the brake vacuum hose going to the firewall. HTH.
Tony
Tony
Old 10-22-2008, 10:45 AM
Vacuum line to brake booster......
Nice pics ty
The vacuum hose is connected to the driverside of the airbox and next to intake manifold #3. The other end is connected a steel tube by the firewall shown in John Walker's post (vacuum leak). See below:
Tony
Old 10-22-2008, 11:08 AM
boy911sc thank you
How do you get such good pics, thats exactly what i needed.
I replace the warm up regulator vacuum hose, some improvement, but still backfires.
thursday the red and blue distributor vacuum get replaced and im going to recheck the fuel pressure.
after that im going to trace the brake boost vacuum line.
Its getting cold in northern ohio, running out of time before it all gets packed away in the barn.
Old 10-22-2008, 02:14 PM
mca mca is offline
mca's Avatar
See the link in my sig if anyone needs a bunch of higher resolution CIS pics.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 10-22-2008, 02:18 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
MCA, thanks for the download of CIS pics, very nice.
Tom
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 10-22-2008, 02:45 PM
