KingSalmon911SC's Avatar
85 MPH Speedometer Question
Hello;
I'm a Newbie! I just purchased a 1980 911 SC. I will be flying to the lower48 next week to drive it & then sadly, put it in storage until spring vacation.
I see a number of 150 MPH speedometers for sale, to replace the 85 MPH original.
Does the 150 MPH speedometer require a different sending unit??
Thank you;
Richard
Old 10-24-2008, 04:57 PM
Originally Posted by Cordova928 View Post
Hello;
Thank you;
Richard
Congrats on your new car! Post pics!
Far as I can tell, the electronic speedos are interchangable; I swapped a mid-80's Carrera one into my '77.
It reads ridiculously optimistic, but the built-in inaccuracy is made worse by the 17" wheel/tire package.
'77 S with '78 930 power and a few other things.
Old 10-24-2008, 10:30 PM
83 CHECKER
Not sure on the answer, congratulations and great success with your 911, I thought the '82 was the year for the old 85 mph, maybe '80 thru '82 ? I get confused and don't know the rhyme or reason as to the 150 or 160 mph speedo's either, they seem to bounce back and forth between models for years, have no idea if there is a correct one for a specific year or does the 'ole what ever was in stock at the time went in, apply here. Best of luck
'83 911SC CAB
'90 ZR-1
'68 TR-250
Old 10-25-2008, 02:43 AM
83 CHECKER
A quick note, going way against the grain here, I would like the 85 mph speedo, the 150 I have has little real usable area on it, the 0-60 area is tiny, seems that having 0-85 over the broad guage space would be far more usefull, as that is where I spend the majority of time, I don't need showing the 150 or 160 to show "how fast it could be" I know how fast it actually is.
'83 911SC CAB
'90 ZR-1
'68 TR-250
Old 10-25-2008, 03:01 AM
85 MPH Speedometer
Thank You All!
Very good point on the usable meter range. I can live with 85 MPH. I just don't want to damage the speedo when I exceed the 85 Maximum.
I will post some pics upon my return. Lastly, I am sure I will be spending a great deal of time (and Money) on this site! I will retire to the lower48 (Idaho) in 3 years. The car is in storage in Idaho & I will restore it between now & then. Can't wait!!!!!!!!!
Thanks again;
Richard
Old 10-25-2008, 03:40 PM
83 CHECKER
Don't worry about the over 85 damage, it will just bottom out and no damge to the speedo.
'83 911SC CAB
'90 ZR-1
'68 TR-250
Old 10-25-2008, 03:53 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
congrates on the car, Another ALASKA porsche owner, enjoy the drive and the above 40 DEG. weather.
ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 10-25-2008, 04:04 PM
I've kept my 85 speedo... ORIGINAL.
No damage at all no matter how fast you go.
You can come pretty close to estimating your speed from the tach.
Old 10-26-2008, 11:11 AM
