irl irl is offline
irl's Avatar
Send a message via AIM to irl
K&N w/ watershield installation question
When i bought my 71T, it came with a awful chrome stock air housing and I recently bought a pair of K&Ns to install on my webers. I have read the posts on no real perf difference, I just want the sound and the look. I dont drive it enough to really do a lot of damage. But I have an installation question because I never get decent directions.
Once I remove the stock top air housing, I am left with the stock base mounts with the clips on the sides. Once I remove the nuts to release the old housing base along with the air horns......Do I place the new K&N filter base down with on top of the carb with the gasket and then put the stock airhorns back on top on the new K&N base?
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 10-23-2008, 07:56 PM
yes.
Sherwood
Old 10-23-2008, 10:14 PM
Yes, and buy the vapor kit with hose from Richard Parr at PMO. His phone is
310-394-0088. It will really clean up all the evaporative emission control hoses
in your engine compartment that used to attach to the stock air cleaner.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 10-24-2008, 12:51 PM
irl irl is offline
irl's Avatar
Thanks,
This site is really amazing, Im going to post the step by step photo process for others in the future.
79 SC unmolested
25 GTS
Old 10-24-2008, 04:28 PM
grease the filter gaskets heavily and keep it oiled
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-24-2008, 05:24 PM
irl irl is offline
irl's Avatar
ronin can u explain that more for me, thanks.
79 SC unmolested
25 GTS
Old 10-24-2008, 10:43 PM
the wheel bearing grease on the rubber seal at either end of the filter will keep dirt from sneaking by.
At the risk of being trashed about the K&N filters allow me to say that I can never find any dirt inside the filter carb top area. Some would argue that routine lab tests on a K&N filter is inadequate. That the oil on a running vibrating engine creates a vapor that captures any oil trying to pass through. If you buy into that you'll understand that oil is vey important to K&N operation.
I re-oil once a year or after one of my big rides which may be 15-20,000 miles. Another pelicanhead posted to re-oil every 10,000 miles.
K&N carb filters aok confirm
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-25-2008, 01:58 PM
irl irl is offline
irl's Avatar
Thank you, one more question. Is there anything I do to seal the paper gasket underneath the new K&N base or does it just lay as is.
79 SC unmolested
25 GTS
Old 10-25-2008, 07:52 PM
lay as is
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-26-2008, 04:28 AM
Cleaned & oiled my K&N last night. K&N recommend cleaning much less frequently than 10,000 miles, unless you're running in a very dirty, enduro-type environment (a standing recommendation is "clean if you can't see the filter mesh").
This is probably because it filters better when slightly dirty
The unique design features multiple layers of oiled cotton fabric which captures the airborne dirt particles. These dirt particles cling to the fibers of the filter and actually become part of the filtering media.
All of our air filters are washable and reusable. They can be easily cleaned and oiled using our K&N Recharger kits as many times as reasonably necessary. In our testing laboratory, we have washed and re-oiled one K&N Air Filter more than 100 times and it still performed up to specification. We recommend you check your air filter every 30,000 miles, however, under most street conditions the filter will not require cleaning until 50,000 miles of continuous use. And yes, we’ve heard the stories of customers who ran their K&N filter for 100,000 miles without a cleaning, but we believe cleaning after 50,000 miles to be the most beneficial service life without sacrificing air flow.
From here:
http://www.knfilters.com/filter_facts.htm#SLIFE
'77 S with '78 930 power and a few other things.
Old 10-26-2008, 10:28 AM
AutoBahned
RWebb's Avatar
... I can never find any dirt inside the filter carb top area.
1st - never use wheel bearing or any other petroleum based grease on rubber!! over time, it will destroy the rubber. use a silicone based grease
2nd - it is not the dirt you see that is a problem; it is the very fine abrasive particles that are too small to be seen with the naked eye
it's too bad they don't make paper filters for this appl. ...
Old 10-26-2008, 11:07 AM
