-   -   Bouncing tach (http://forums.pelicanparts.com/porsche-911-technical-forum/437864-bouncing-tach.html)
OldTee 10-27-2008 12:30 PM
Bouncing tach
Upon shifting, tach bounces more than it did, ought. I have seen this before but don't recall the source. About to fail CD box? Any Ideas.
Porsche_monkey 10-27-2008 12:38 PM
I think this has been tied to a generator issue, voltage control IIRC.
mhoffman 10-27-2008 01:02 PM
ground strap on top of transmission. If not that, voltage regulator, in which case check also your battery box for acid spray and corrosion, rinse with 10% baking soda solution and flush with clear water...
old man neri 10-27-2008 01:39 PM
Ya, mine does this as well every time I shift. I think it has something to do with a broken spring inside the tack.
Porsche_monkey 10-27-2008 02:45 PM
The defective damper suggestion sounds as believable as anything.
