OldTee's Avatar
Bouncing tach
Upon shifting, tach bounces more than it did, ought. I have seen this before but don't recall the source. About to fail CD box? Any Ideas.
Old Tee
all 911s sold
Old 10-27-2008, 12:30 PM
Slumlord
Porsche_monkey's Avatar
I think this has been tied to a generator issue, voltage control IIRC.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 10-27-2008, 12:38 PM
Matt
mhoffman's Avatar
ground strap on top of transmission. If not that, voltage regulator, in which case check also your battery box for acid spray and corrosion, rinse with 10% baking soda solution and flush with clear water...
79 SC Targa
87 m491 Targa
73 BMW 3.0 CS
73 BMW R75/5
88 BMW M6
Old 10-27-2008, 01:02 PM
old man neri's Avatar
Ya, mine does this as well every time I shift. I think it has something to do with a broken spring inside the tack.
Old 10-27-2008, 01:39 PM
Slumlord
The defective damper suggestion sounds as believable as anything.
84 Cab - sold!
Old 10-27-2008, 02:45 PM
