E-Grind cam specifications
I just got back from machine shop to get my specifications for my cams.I had e cams put in for a 2.7 rebuild with mahle RS 90 mm p&c's webers,ssi's and sport exhaust.The specifications are as follows.These were reground from my CIS cams
-Intake duration 219 at .05 valve lift .420 -Exhaust duration 212 at .05 valve lift ..396 I can't find these specifications on any chart.Does anyone know if these are indeed e cams or in fact something milder.
Brent Lineker 1975 911S weber conversion. |
Hilbilly Deluxe
According to John the Camgrinder's chart, that doesn't match any stock cam.
http://www.drcamshafts.com/911profilesprint.htm The E should be 230º @.050"with .405"lift on the intake and 222º @.050"with .393"lift on the exhaust. Tom |
That is the same chart I was looking at too.The machinest told me that the factory specs are the ones he gave me,but I can't find where to look for factory specs.
Dumb question, bit off topic. I understand lift and duration, but was does the "at .050" spec tell me? Thanks
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Hilbilly Deluxe
Tom |
Thanks Tom, very helpful.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
They gave me timing specs of- intake opens@29 btdc closes @39abdc
-exhaust opens@39 bbdc closes@19 atdc
ok
those 1970/71 valve timing numbers are incorrect says Allan Caldwell. the 1969 and the 1970/71 E cam are same so says everyone. The yellow was circled by Stoddard. ![]() sorry for my confusion
