Free minder
Uh oh...It`s snowing and I got the 911 to work...
This morning was rainy, but since I decided I was turning my 911SC into a daily driver, I did not take the SUV.
Now, the temperature brutally dropped, and it is snowing! (atypical for NJ in this season, as far as I remember). Sooo, my drive back home may be on the snow...I have good tires, but not snow tires. Any driving advice ? (That will make it 911 technical forum material ).Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Yikes!!
I had that happen to me last spring 80 miles away. What tires do you have? If they are High performance summer they are not gonna like the cold temps. My Fuzion's were like ice skates, even in just a couple of inches of wet slushy snow. If they are more of an allseason tire, you may be ok.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Free minder
The tires are Khumos ectsa, I think they`re all season. Got those V channels to evacuate the water from center to sides. I`ll have to just take it easy...
Aurel
Hopefully, it will be cleaned up by the time you leave. With temps close to or above freezing it won't stick.
Friend of Warren
I got stuck in a blizzard one winter before I changed over to my winter wheels and tires. 6 inches of snow on the road when I headed home on the Bridgestone SO3's. We have some really steep hills around here. Lots of slip sliding, but it would actually make it (slowly) up every hill.
With my Blizzaks I feel like I have 4 wheel drive.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Watch out for the salt trucks! If New Jersey is anything like Ontario, there'll be 2 inches of snow on the road with 5 inches of salt over top!
1979 911SC "Frankencab" Dave |
Less brakes, more gas!
911's do NOT turn in the snow... never had trouble getting up and going and I was on Z rated Dunlop SP 8000's... but when you go to turn you better be going slow. If you can, go fill it up with gas before you go anywhere and put any other weight you can on the front in the trunk for your drive home. Just take it easy and you will be fine...
... this assumes your defroster works! and you have heat! Neither of which I had at the time... bbbbrrrrrrrrr-Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
(the shotguns)
perhaps this is a good time of year to ask how the defroster works..........
i know the heat lever on the floor but have zero clue about the sliders on the dash...
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
move
Move to Arizona
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
Free minder
Normally, I think defrosting is all sliders to the right. But in my case, it blows only cold air to the windshield. I don`t know if that is related with my recent heat backdate...I get good heat to the feet though. I`ll get a few wipes just in case. And a brush to clean the car too...
Aurel
durn for'ner
The Swedish rally driver Björn Waldegård always claimed that the 911 was far better than other contemporary cars in snow. Mostly because of the outstanding traction.
However, I suppose your car is not set up like his car was and that he was not referring to driving in traffic. So even if you are as accomplished a driver as Mr. Waldegård was...it may be prudent to really go by the old saying - slooooow into the bends. Be safe!
Markus Resident Fluffer Carrera '85 |
Find a female employee with a BIG RACK and ask to spend the night!!!!!!
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Hey buddy, im at work in Maplewood NJ (near exit 143 gsp) in my 911 as well (daily driver, Kumho Ecsta ASX all season high performance tires).
You can be rest assured that after work you will not be in this alone. (30-40 mile drive back home). And yes, i did enjoy wiping the fog off my windows on the way in this morning while i was driving in the downpour.
1984 Porsche Carrera Cabriolet - sold, regrettably 2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably 2005 Mercedes C230 Kompressor Sport Sedan - now... Last edited by dimeified; 10-28-2008 at 11:14 AM.. |
cycling has-been
drivin' the nine-one-one in the snow - more fun then hot laps at NJMSP.
they do handle in the snow. and where do you work? is't not snowing in Red Bank and at a balmy 41 degrees. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
911 are fine in snow. If you are in traffic you shouldn't be driving fast enough to really have scares anyway, except for other's stupidity. In that latter case, your cars dynamic traits will be exemplified.
The key to driving a car safely in low traction conditions (on a public road) are the same for whatever car you have. Remember, all cars have 4-wheel-brakes. Just be smooth and anticipate everything. Last of all, try not to brake too hard if you don't need too. The guy behind you may not have the same traction as you, especially near intersections. It is much safer to go through a late yellow than slam on brakes. The cars getting the green also have low traction so it is not like they will be gunning through the intersection. When living in Chicago, it amazed my that people tended to brake more aggresively than needed when it was snowing. Often slamming on their brakes so they didn't go through a yellow light. Never onec do I think those people thought of those behind them. |
Free minder
Aurel
I drove a beetle without heat through 2.5 michigan winters (cat-sized holes in floor pan sidelined it eventually). It was a fantastic snow car until it got 6+" deep, then the front would catch on every rut and the car was all over the place. I had 245/60's on "wagon wheels" in back, so the rear tires were 911-like.
And, when desired, lots & lots of sideways fun! I used to practice the "Rockford Maneuver" in parking lots after a fresh snow ...
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Be glad you're not west, in PA! Acck, I need to move west..or south.. (And I'm not getting ANY snow here in CT, the thought just freaks me out! It's OCTOBER!)
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
N-Gruppe doesn't exist
stop your *****ing and drive
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
Free minder
I made it home with no problem, but the defrosting sucks. Making it work correctly will probably be my next project. Weak defrosting on the SC is the main incentive against inclement weather driving, IMHO.
Aurel
